have installed fine on many machines for months but today I got:
Downloading packages:
cuda-visual-tools-8-0-8.0.61-1 FAILED ETA
http://developer.download.nvidia.com/compute/cuda/repos/rhel7/x86_64/cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=cuda clean metadata
I used wget to download it directly and try install but it failed with
error: unpacking of archive failed on file /usr/local/cuda-8.0/libnvvp/plugins/com.nvidia.help.pug_8.0.0.jar;58fb8ef9: cpio: read failed - No such file or directory
error: cuda-visual-tools-8-0-8.0.61-1.x86_64: install failed
Luckily all files were still in /var/cache/yum of a box I did last week and had a good copy so I could complete by install.
fst
April 24, 2017, 1:56pm
2
I can confirm that this is happening for me as well.
Unfortunately, since this is my first install, I don’t have the luxury of grabbing a valid package off another box.
Do people who can fix this monitor the forums? Perhaps there’s a better way to get their attention…
I’m trying to install a new server for some GPU work and having the same problem. Unfortunately I have no backup packages too.
I’ve just download the Centos 7 repo (cuda-repo-rhel7-8-0-local-ga2-8.0.61-1.x86_64.rpm) and I experiencing the same problem.
The problem is still present with the yum repository for CentOS 7. I cannot install visual tools, hence the core packages which depend on it cannot be installed properly.
t_vb
April 27, 2017, 12:46pm
7
Still getting the error
http://developer.download.nvidia.com/compute/cuda/repos/rhel7/x86_64/cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm :
Trying other mirror.
Error downloading packages:
cuda-visual-tools-8-0-8.0.61-1.x86_64: [Errno 256] No more mirrors to try.
Whatever solved the Hash Sum Mismatch - Ubuntu 14.04 did not solve this.
Still the same error on Centos 7. The local RPM download still works however.
The repo isn’t working for me, and neither is the local download. I was able to pull down the RPM, but when I tried to install it I get:
[root@box ~]# yum localinstall cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-manager
Examining cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm: cuda-visual-tools-8-0-8.0.61-1.x86_64
Marking cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package cuda-visual-tools-8-0.x86_64 0:8.0.61-1 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
cuda-visual-tools-8-0 x86_64 8.0.61-1 /cuda-visual-tools-8-0-8.0.61-1.x86_64 309 M
Transaction Summary
Install 1 Package
Total size: 309 M
Installed size: 309 M
Is this ok [y/d/N]: y
Running transaction test
Transaction test succeeded
Running transaction
Installing : cuda-visual-tools-8-0-8.0.61-1.x86_64 1/1
Error unpacking rpm package cuda-visual-tools-8-0-8.0.61-1.x86_64
error: unpacking of archive failed on file /usr/local/cuda-8.0/libnvvp/plugins/com.nvidia.help.pug_8.0.0.jar;590227b5: cpio: read
Verifying : cuda-visual-tools-8-0-8.0.61-1.x86_64 1/1
Failed:
Complete!
Red Hat Enterprise Linux Server release 7.3 (Maipo)
I just tried this again today. Still doesn’t work on RHEL 6 either.
Seems that cuda-visual-tools-8.0-8.0.61-1 RPM is broken on both RHEL 6 and RHEL 7.
Here is the base64 of an rdiff delta to fix the rpm
cnMCNkYAYABKCAAIAEtoAAABcABKCAAIAEoIAAgASggACABKCAAIAEoIAAgASggACABOAAIIADAA
TgACEAAoAE4AAhAAEABOAAJwABAATgACeAAIAE4AAngACABOAAJ4AAgATgACeAAIAE4AAqAAEABO
AAKoAAgATgACqAAIAE4AAqgACABOAAKoAAgATgAC0AAwAEoIAAgATwADCAAKxCgATgGVYAAQAE4K
x0AAMABOAZWgABAATwrHgAAAXIAAQc1f0ocMr1Cf5QAHQPi/yyr5V7ppx8f0W+Mnfrm9L4blX0uw
wDdRf9FFO2g+1uk84uBaRp+L0Z/Kgi4YG10aEFCnMjDGOMmxpArnMVbo9Aw4iEFoszm7W9FK0cEk
ZGTvvvODcsMm7iRmNd9fCEw07gTpWSIWqE7YYqIjTq1Cq9A4g36q0iNGgyQq6RaypldYRil1mYKL
gqnbBNpUOtpam0AukmZYPvRamIjTqam4cN4EVATL38/agTJSf1/wimkbEAniGtqiPxxBxdI2T5+d
TgtzWAAQAEHNsWLe8IYJsqjDiTs4VGVYkVb9MFjsaCeuaJI0cGmS7Fj9qUc+l8G1s4VXnd9PiigE
ZzdHgHgUlOt4NGah1TvaUPEkc8B1VnN1ZTNiGx+/PeDTaWL8T3FK6rP3tVq71f1ilA0egoEpCg2x
g9o0j5+l21FwkIp8HDA+zfWEdKKegAlv2c0iAUhqyc+BGM1rOM/YlZ/pcixrSyeW/RYOynLuCTGN
4IUjjxatUqc607TibNNvv4UwJjdG7vOvHIfzp93v3doCW31hULEQXh6OPU4B8kAACABCBy6fevk0
FrLQFQORxUakgL3c/d384Mue8DgvxFdK/LdQivso0mBPezXBu6GgqgzSDuG/CsMrNmJ3W+bpiKrX
kAH1RTJbyN7owFSyov70vnE9trjXfPt2clkulY/bFBqI+numk7WMho5/yJjzDwmxw5V5ik9JkaVO
rLeWv4+UPo6Pb1lmpAV9B77iowFRqf4phcu8iZQfFdFRV5EynliMjelK1Hcrq2sahF+NVXloO0/Q
oxHQ/ynTthlDaKsfU399xbd/atm72ad5P4+kkhwSUlynh9gZ8K2LxHWwuW5GXf227F2tTGoKJ7LW
2Xzu2U+8+gTgLEpi0HWdOkTzkh5/PmUO231F+A3gdCRz+d5Ns3BMQbvbOiDkt9g5bzqLenm1DPOI
GrGG0YOTVYC+YqZ8yMXrcxgUntoJi/HF00eIIU1umL4apTSOiBVzXAYPI4bUvE5pIfsNP1GFKX73
mH7QIzJxkmKr2cj43zIUP4S0hhIbMkR40ZAYE/OtqYkHJ9PnKK+JAy+SDbcTCGQu1QJWMqxbFQDE
+uZs+T+Rv5LTIWoxGX6q4HP1jEwUEeD+YyLxhGxIhrKmXcivDQ7URP698ezg7i/fOjuF29rbZ6fS
qddgJGL4+fh0PKEqtIBZOs5HCW4OfLsPrq6hIf8QO/fZd+9wMqjI6CqLi2nyCwtzRfxhrGQG4REQ
/KOjkd9BQc3G6ebV/fbczEVT1z0IzBtlwA7V5GIGcDPpH/uSmev1w9v9XmudFdFVmskKL+GQkDST
ZQ1G0zhR8fHLmFBVVARen66soobwsvD/+gPd8O/X5TpR0tMjEBERHaoOOjs7088JzG0Cvw/ShoaE
houKqzfFiRskhPLlLoukc9nOECRy/rO36kmsPAriO2GQNGnfR27FppLtCM2ywH5jlWQ9OTklEXkb
iqmpOKMhrrDBskSKy1z5kvhllOd5QiGfz6Mq2r3OYn89xHTxBDODyxCURSzUPSIzXXUt2qAjLb4T
WrtRN1EKOjam1IJfCsprghxJyyp+06gZLdlmCOWblKyjfGDe2l+pCd8L+ktzQzXL9DyZjhi1WbjB
B8Q+kYSsTy2CKp75a72cyGX5Ks4S5vVYbVG1tjyysmFSZppBU2MabKnyLOmMsrqo+UyPDCHLN7xm
PlVYWvJWseTOFFyjvojs81Kbc+3+WDVKjeLaAkymCFJ7Sfr/7nqivMOSxzu1I6ufkxYT5xXsygMU
uujVW/X8CWyRhW8HXrCCe0BkSdCa4synP0/d0UcEEu1PF+sAHs1JJ80w7S5vUq1YUVfxxiQ50yv4
PlOqUFNfFO/yKx6V5meweePzplJmttxG6kVmcKXWxKYlHXPgnKREDNh4eHmIlc3SOisVFVLRdh+y
jaIFcsYPmNzafVhrwN/bTQTglpmNdyOD4sJvfe0UJBbG6iE36qjL/FtNSkto+8yduccmjtFyA74R
FXvfl8Zfvy+bqmJHjTG2etj9pcRiBvrM2GlVPkWfa5TTbGcdg+IwqSSb/mDB0qR4oyUqPWH0it3x
L2PpnWRM1MZG3bM78Rf9nMtTN+yov13EqvHYOxBWuCJT8pdEis/bVpN9ZHsnCXzeccMSbLrwvlJO
mBlYztLhN5nQ+SeDKZmI/t2Ib2ffqfQD6WpqFYb4TAEvlnJ9MD7OE4SCWUfvOjeRJTtVBlDl/c5J
22rALU+nns6Xx2q7wmdnMBILIGNibH2JGbuZ95FWWj9EGB+A9Ev7eujGt4xd1tEun4qz8VfS2yOn
Dz/qJpUZ5tZfShkFqzsTIC37/UqrNDo5ElSZl5vR+NTry37hHeE1MDJ/8XgM3kfTmWzIcrd18X3R
zZCvbYf9mg3Ajry6qyhs9VNUX2o67sygX2quJtvZB+3vlEmlMwN3AYwYbjZh3seypcL37qPxhh8H
CBPrJjzmBgD2T1E83uxbliNWp1FLJncknHdSb1H/CohFClCYuTZ7enKa9ur1f/2gbgE0IYYHvV8W
+plOVmW5+2lFW4Pab2Oii76JPevxkCbuxPHnMQsD3jKy7dFD909fh/IJl4+3fZl9wdH1Ur2fiC1m
naLTTlieasWaj+ADbwwpqPr0Q9SuPh0eHkAMU/iWWK+UfF7mojKAtromTKTdQig1VbbmmX1S/vw5
jjfwE/TjIsGljET92+4DuUpbQ0N8aWGIE+ZLZnruTwZNtGi6ZoiiR5/8pwZqNWEFbgaJ+paFv/Hy
mynAbDZjXQZz8hpa/uLKp0OsdXi6QVl2WwL4lzEJcaMlmpJB0rMHcwO1mbiHgdyonxuKv1vwo1ad
8m3ZUabuGE+O2ThyvZ8bWOQ6ZmNzLrpCUXML+VS3kNQu/z6XUsYfT6R+ez4dSzIP1UmyZHhEXsub
NnykqeFFl+Dy+Dtq5s4dRf31ugbW7QHVbXf7BwNtP4z0ooYYP/g1InjCTPoC8MLx4ySk4+7c/dwk
5f4Z6/jhAjegeE4Lc3gAGABCBzjXz4sJyBhL/7uu2aBgaaiKBJX3FLKIq3tPBFsjoNYDWZw2D+nJ
M3FOpIOEzw0VTRB/gA8mmGCIAA6I6c6Vl2jY+ExsqkxrLevNxT6Dx15CvTFcfZiJ8fOgDgFtQsXp
Jy+foS0RcCLzNjgKXnlPlJXsGdMu3D7nuod7fuHF8v3Lqf8UVSvIMm27JybQbGzCa3XthvkkAzQe
DYwAn7j4+DTneg7asi5E66iF9TxBavzjNa8NdNL612zqvemfPbTwBBb17Z2zbTkn31wIwVuuuHSG
eVpB/k2l07NODOyPXVnRVm+wh1W1WKplcDvm9EI9ANgqUkZ5aAhWcTvsob979y7GgIQa9998cnT0
o76hoe7RUnP/GyNG4Bm/JMmblLi43HMqFstFZReyzMzVv0qrTGHZUlXUFEXDR10npJBL1ZGBO8u6
5crWl/sqydxOiN/nVtPdIbR2Eysrq0mgFlEYLqushFVJ5iIsOxfTu/oiC0ORBtWogam76iLuY9Tf
nr6xA5BCcfobxuBv3DVZSmmeb5OGvpAV2T7Ro+jX9A5kDpqjRuhSi9Pw8PDYaC8TThYtCwSZ7Vy4
5kQoDMQzcUgC5DHffv/5W6sVV4GVslNFIvmjNWz+0NB/tUy18HaT//xi6SgeCSrKWEn7j1+/da7k
h4a/8+N7AAbQP/Dg346DqP3i1okTrsgov9oYHciE93uAYKTAgr86804Fh1PD2DrxOQJJ5rhSDLvn
D570t+iT/YKs/pc9+9cXM21FF0GsfHyERiOp3UFolI82XC6nZMPJnL69ve9zrH69l9oDVyysKzuX
jAYyXAqfX3ZFAy8o8JHu3/AIYSKkmVlZsdz900VK0iX1DsG2lIs7vTCbpTUJOLumYvQ/EI0/Lita
ugbj1/3G8Wg2XNPjlsoGXayiw7T6HUQC3WnFG+akriyxgrPj4y5vD7ePQM+X5KUZM+BYPkU6rf4f
NASDjIzMe0lJYV8ohMmoKAxMTCgiIiIIKKhC8loRkz9iFBi8pwiVx1kCjRJLY2Nj80984fcmY6Lz
8z4uLqZ1dnbOlyAfGRqSTFjLyu/Sehkth4qChuUXmG9NHtT0Bs3h93EBbOB/H0j50kBg0Eat1/rn
JPFh42pVZVpMh77qqnP0ri4REjo6nFzzrK9NqmIkDP0xXPUIv77u2840VN7QTPl2gPRbu3EW2uYv
JZiY3uSweV5a3lbbnv4XSpKmOozf9muC8j/YYCZjql581SjeEBdcsEbH8iIQ64MtE6/hjE0ml6Gc
D6z51Z+YmRIEKSP87mKjHp1baC090Q+MLYepLUjACxf4kTAvPHDpN33rW8NayVo6CRH4YSJu/2N7
FMPBAQWCWPoLwlIXZfKwRBquouoVh2SLThlZWR6mSqYYx9KoPn2fOXOZ+eDXrL+6v0k9tlLFuouN
KY37qdHHI33MeCPb1yql8Xi0DpIjTv36fZdXGsZYCHf+3RIEs/RmkhObBZFmKfkeC4zr7jOmqbUn
1IFqvzrQ0CU+DdLc565TbLchvoCIRnn5kazEphdj2XfWTZUU8DjCzlLTYAnrWqdnuFW4n4VXXZ5e
rxWGi6dVygwZFiEq3jQFU2/KDDklTyuIcRpcstkySXxfPfHqcTktmAxIWenmTN7OM+KEzR2fH/sr
FsltpUpJSsr6TP0Kl76cbruJ3caIc4MLDfyTNiuilqSSRMl7WP7Q6hBPUfP6r0vzn8FGmVP3OIMu
Z0pdm135tHUN7kwtdYZqDZ4Ua/zYycMdfS5Wq0isnnHn6/C0jeqIogkSKoEh7xWwnqXUnTMB1wcv
u53XV7ecd5IkThPoP+sLeo8sfo82l5G3XogwZbxEmTgqrenx3N+oBun/gWpI9kr8/cZ+o9QHCKWT
Ub65t6Ztod6+GDpe89HgIEryD53ETl6uRNXyuqFouJ5P5DII7opT8R3lGk0Ptb0onnou7VEBfcK+
GE0LxY9QCifNiDrdTMHVXIecdzBB/V5slq2G14dm7nbUmPp1Nhju+hJQyHRlNvYV2YlYauhlQVHe
upeOKTbz7xRAejbrFirqPoqUHATbEH4gd9FejIUbpFOPnRaB8LD2SXH0tbE1JUup5nNXg2X7/Pk1
mQ+eRrS3LKXmC8u/uIBQV0xH9YrOMmNz/qoSMLTvOBAKIxG+y46uSrxl/ItFmZ/xX2gAyEWwpPhi
uNO2Voydp7GMaAtL9ktnr6U0dqhVupPZqxsYewQZ0V43iIyJLt6PHZale6+4pXpFrveCdhS0CC6K
zwQvFEmPJapmdZQcIM3enrEw0aKGynhpu5oxyrKhqW3T9nDqyQDjz756BjSWSJ7V132lpNYQ0NAZ
mZhzMeOCcluTWusEzWfppCNVmdaLDjliP84RB+gB/kIngMQg4uhMX89LQRQ3DtepiRnWK1cxq52b
HoR9f6roSZmduJAYDQJgACEWcwOA16pRLPko8hJ8AarYYSK9ODn0zBOPAdxPCyRAAADruABOAoPg
AAgATwwQAAAE+jgeAA==
Save these lines to a file named cvt.b64, download the broken rpm (link in original post),
rename to rpm to “broken.rpm” and then run
base64 -d cvt.b64 > cvt.delta
rdiff patch broken.rpm cvt.delta cuda-visual-tools-8-0-8.0.61-1.x86_64.rpm
You can then use “rpm -iv --nodeps” to force install the rpm and then try to yum
install cuda from the repo.
thanks for bringing this to our attention. We are now working to resolve this issue and will get back as soon as there are any updates.
thanks,
Nvidia Team
