Cuda & VS2012 in a build tree
I try to integrate Cuda5.5 into our build tree which is based on build & nmake.
The problem is that nvcc complaints that it cannot find compatible compiler when I point it into the one we have in the tree (we use visual studio 2012 compiler). Setting paths to compiler in program files works OK but this is no-go due to automatized build system.
Do you know how to persuade nvcc to use cl.exe in our tree?
Also, uncommenting --use-local-env causes nvcc to hang.
!if defined(CUDA_SOURCES)
@echo Compiling CUDA files: $(CUDA_SOURCES)
$(CUDA_TOOL)
$(CUDA_TARGETS)
$(CUDA_INCLUDES)
$(INCLUDES)
$(CUDA_DEFAULT_FLAGS)
–cl-version 2012\
–use-local-env \
    -ccbin "C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64" \
-ccbin “d:\OurTree\Tools\x86\amd64” \
    --keep-dir "$(OBJ_PATH)\$O" \
    -maxrregcount=0 --machine 64 --compile -cudart static -use_fast_math \
    $(CUDA_DEFINES) \
    -Xcompiler "$(CXX_DEFAULT_FLAGS)" \
    $(CUDA_SOURCES)
!endif
x86\amd64 is a copy of x86_amd64.
I found correct structure.
If anybody is interested, nvcc is trying to locate vc\redist{x86|x64}\Microsoft.VC110.CRT\ and uses that for compiler version verification. Compilers themselves must be located under *\vc\bin{x86|amd64}
