seeing a lot of discussions and no solution to the problems, I will state my problem once again.
I have VS2008 installed and want to use the nvcc compiler. As this is still not working, I installed VS2005 Express on a new machine, including CUDA 2.0.
When I start nvcc.exe it complains that nvcc cannot find a supported cl.
What could be the problem?
To explain a little more detail, I want to create a custom build tool which creates all the needed binaries. I only have to CUDA source files in my solution, the rest is generated by the custom tool. This is necessary for us, because we working in a C# environment and there is a lot of stuff to do, to get a regular DLL which I can use in C#. In fact the workaround to install VS2005 is not suitable for me. What I want to have is to copy only the necessary binaries from VS2005 (cl.exe and everything that is needed) to a common directory and start the CUDA compilation from there.
I’ve got the same error message with nvcc2.0+Visual Studio 2005 Express : “Only MSVC7.1 and MSVC8.0 are supported”.
cl.exe from 2005Express gives version number “15.00.21022.08”. So, where to get that old compiler? Or there is a workaround?
thank you for your suggestion to check the path. You were right, I had to set the --compiler-bindir explicitly – I’m so stupid… I have checked this on another machine, but not on the current installation.
Do you know what files and configurations I need to run nvcc without VS2005 installed? I want to copy the files from the original VS2005 to my project and create a custom build tool. Unfortunately nvcc doesn’t tell me what’s goind wrong when not all necessary files are
