cuda9.0 installation error /(after remove 8.0 for tenforFlow)
I am using ubuntu 16.04, 1080
I have tried all methods but seems not working.
since deb(network) install automatically 9.1, so I don’t use deb(net)
but for others
  1. runfile case
kai@2kai:~/Downloads$ Run sudo sh cuda_9.0.176_384.81_linux.run --override
Do you accept the previously read EULA?
accept/decline/quit: accept
Install NVIDIA Accelerated Graphics Driver for Linux-x86_64 384.81?
(y)es/(n)o/(q)uit: y
Do you want to install the OpenGL libraries?
(y)es/(n)o/(q)uit [ default is yes ]: y
Do you want to run nvidia-xconfig?
This will update the system X configuration file so that the NVIDIA X driver
is used. The pre-existing X configuration file will be backed up.
This option should not be used on systems that require a custom
X configuration, such as systems with multiple GPU vendors.
(y)es/(n)o/(q)uit [ default is no ]: y
Install the CUDA 9.0 Toolkit?
Enter Toolkit Location
[ default is /usr/local/cuda-9.0 ]:
Do you want to install a symbolic link at /usr/local/cuda?
Install the CUDA 9.0 Samples?
Enter CUDA Samples Location
[ default is /home/kai ]:
Run: command not found
  1. deb(local), step4
    sudo apt-get install cuda
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda : Depends: cuda-9-1 (>= 9.1.85) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
step3
sudo apt-get update
Get:1 file:/var/cuda-repo-9-0-local InRelease
Ign:1 file:/var/cuda-repo-9-0-local InRelease
Get:2 file:/var/libopencv4tegra-repo InRelease
Ign:2 file:/var/libopencv4tegra-repo InRelease
Get:3 file:/var/visionworks-repo InRelease
Ign:3 file:/var/visionworks-repo InRelease
Get:4 file:/var/visionworks-sfm-repo InRelease
Ign:4 file:/var/visionworks-sfm-repo InRelease
Get:5 file:/var/visionworks-tracking-repo InRelease
Ign:5 file:/var/visionworks-tracking-repo InRelease
Get:6 file:/var/cuda-repo-9-0-local Release [574 B]
Get:7 file:/var/libopencv4tegra-repo Release [347 B]
Get:8 file:/var/visionworks-repo Release [1,999 B]
Get:9 file:/var/visionworks-sfm-repo Release [2,003 B]
Get:10 file:/var/visionworks-tracking-repo Release [2,008 B]
Hit:12 Index of /ubuntu xenial InRelease
Ign:16 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 InRelease
Hit:17 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 Release
Get:13 Index of /ubuntu xenial-updates InRelease [109 kB]
Get:14 Index of /ubuntu xenial-backports InRelease [107 kB]
Get:15 Index of /ubuntu xenial-security InRelease [107 kB]
Hit:22 http://storage.googleapis.com/bazel-apt stable InRelease
Ign:23 Index of /ubuntu xenial/main arm64 Packages
Ign:24 Index of /ubuntu xenial/universe arm64 Packages
Ign:25 Index of /ubuntu xenial/multiverse arm64 Packages
Err:23 Index of /ubuntu xenial/main arm64 Packages
404 Not Found
Get:27 Index of /ubuntu xenial-updates/main amd64 Packages [775 kB]
Get:28 Index of /ubuntu xenial-updates/main i386 Packages [713 kB]
Ign:29 Index of /ubuntu xenial-updates/main arm64 Packages
Get:30 Index of /ubuntu xenial-updates/main Translation-en [321 kB]
Get:31 Index of /ubuntu xenial-updates/main amd64 DEP-11 Metadata [319 kB]
Get:32 Index of /ubuntu xenial-updates/main DEP-11 64x64 Icons [227 kB]
Get:33 Index of /ubuntu xenial-updates/universe amd64 Packages [627 kB]
Get:34 Index of /ubuntu xenial-updates/universe i386 Packages [576 kB]
Ign:35 Index of /ubuntu xenial-updates/universe arm64 Packages
Get:36 Index of /ubuntu xenial-updates/universe Translation-en [252 kB]
Get:37 Index of /ubuntu xenial-updates/universe amd64 DEP-11 Metadata [246 kB]
Get:38 Index of /ubuntu xenial-updates/universe DEP-11 64x64 Icons [331 kB]
Get:39 Index of /ubuntu xenial-updates/multiverse amd64 Packages [16.4 kB]
Get:40 Index of /ubuntu xenial-updates/multiverse i386 Packages [15.5 kB]
Ign:41 Index of /ubuntu xenial-updates/multiverse arm64 Packages
Get:42 Index of /ubuntu xenial-updates/multiverse Translation-en [8,344 B]
Get:43 Index of /ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,964 B]
Get:44 Index of /ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
Get:45 Index of /ubuntu xenial-backports/main amd64 Packages [4,844 B]
Get:46 Index of /ubuntu xenial-backports/main i386 Packages [4,836 B]
Ign:47 Index of /ubuntu xenial-backports/main arm64 Packages
Get:48 Index of /ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,324 B]
Get:49 Index of /ubuntu xenial-backports/universe amd64 Packages [7,400 B]
Get:50 Index of /ubuntu xenial-backports/universe i386 Packages [7,080 B]
Ign:51 Index of /ubuntu xenial-backports/universe arm64 Packages
Get:52 Index of /ubuntu xenial-backports/universe Translation-en [3,996 B]
Get:53 Index of /ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,088 B]
Get:54 Index of /ubuntu xenial-backports/universe DEP-11 64x64 Icons [2,717 B]
Get:55 Index of /ubuntu xenial-security/main amd64 Packages [490 kB]
Get:56 Index of /ubuntu xenial-security/main i386 Packages [437 kB]
Ign:57 Index of /ubuntu xenial-security/main arm64 Packages
Get:58 Index of /ubuntu xenial-security/main Translation-en [212 kB]
Get:59 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [67.7 kB]
Get:60 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [68.0 kB]
Get:61 Index of /ubuntu xenial-security/restricted amd64 Packages [7,224 B]
Get:62 Index of /ubuntu xenial-security/restricted i386 Packages [7,224 B]
Get:63 Index of /ubuntu xenial-security/restricted Translation-en [2,152 B]
Get:64 Index of /ubuntu xenial-security/restricted amd64 DEP-11 Metadata [200 B]
Get:65 Index of /ubuntu xenial-security/universe amd64 Packages [347 kB]
Get:66 Index of /ubuntu xenial-security/universe i386 Packages [300 kB]
Ign:67 Index of /ubuntu xenial-security/universe arm64 Packages
Get:68 Index of /ubuntu xenial-security/universe Translation-en [130 kB]
Get:69 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [107 kB]
Get:70 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [142 kB]
Get:71 Index of /ubuntu xenial-security/multiverse amd64 Packages [3,464 B]
Get:72 Index of /ubuntu xenial-security/multiverse i386 Packages [3,624 B]
Ign:73 Index of /ubuntu xenial-security/multiverse arm64 Packages
Get:74 Index of /ubuntu xenial-security/multiverse Translation-en [1,744 B]
Get:75 Index of /ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [212 B]
Get:76 Index of /ubuntu xenial-security/multiverse DEP-11 64x64 Icons [29 B]
Err:29 Index of /ubuntu xenial-updates/main arm64 Packages
404 Not Found
Err:47 Index of /ubuntu xenial-backports/main arm64 Packages
404 Not Found
Err:57 Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found
Fetched 323 kB in 2s (151 kB/s)
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
E: Failed to fetch http://kr.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found
E: Failed to fetch http://kr.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found
E: Failed to fetch http://kr.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found
E: Failed to fetch http://kr.archive.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
and step 1,2 seem ok
sudo dpkg -i cuda-repo-ubuntu1604-9-0-local_9.0.176-1_amd64.deb
Selecting previously unselected package cuda-repo-ubuntu1604-9-0-local.
(Reading database … 291594 files and directories currently installed.)
Preparing to unpack cuda-repo-ubuntu1604-9-0-local_9.0.176-1_amd64.deb …
Unpacking cuda-repo-ubuntu1604-9-0-local (9.0.176-1) …
Setting up cuda-repo-ubuntu1604-9-0-local (9.0.176-1) …
sudo apt-key add /var/cuda-repo-9-0-local/7fa2af80.pub
OK
please
sincely
