Says to install Cuda 9.0
I chose x86_64 ubuntu 17.10 legacy release 9.0 deb file.
I get the following errors:
$ sudo apt-get install cuda-9-0
The following packages have unmet dependencies:
cuda-9-0 : Depends: cuda-runtime-9-0 (>= 9.0.176) but it is not going to be installed
$ sudo apt-get install cuda-runtime-9-0
cuda-runtime-9-0 : Depends: cuda-drivers (>= 384.81) but it is not going to be installed
$ sudo apt-get install cuda-drivers
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
cuda-drivers : Depends: nvidia-384 (>= 384.81) but it is not going to be installed
Depends: nvidia-384-dev (>= 384.81) but it is not going to be installed
Depends: libcuda1-384 (>= 384.81) but it is not going to be installed
Depends: nvidia-opencl-icd-384 (>= 384.81) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
$ nvidia-smi
Driver Version: 390.67
$ python -c “import tensorflow as tf; print(tf.version)”
ImportError: libcuda.so.1: cannot open shared object file: No such file or directory
Any suggestions?
