I need to use Tensorflow-gpu 2.3.0, for this reason I need Cuda 10.1.
Then I used this method:
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
sudo add-apt-repository "deb https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/ /"
sudo apt-get update
sudo apt-get -y install cuda-10-1 # and not cuda to avoid installing version 11
Unfortunately I have:
$ sudo apt install cuda-10-1
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-10-1 : Depends: cuda-toolkit-10-1 (>= 10.1.243) but it is not going to be installed
Depends: cuda-runtime-10-1 (>= 10.1.243) but it is not going to be installed
Depends: cuda-demo-suite-10-1 (>= 10.1.243) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
If I try apt install cuda-toolkit-10-1, I get other similar errors.
Any idea?
