I’m trying to compile a piece of .cu code for both device and host using the CUDACC preprocessor variable. With the code below my error message tells me that blockDim is an undeclared identifier. I have tried inserting this code also into some cuda examples (incase it is my project settings), but no luck. Am I barking up the wrong tree, or should I hopefully be able to get such a technique to work?
Thanks,
Paul
__device__ __host__ int test_both() {
int x = 1234567;
#ifdef __CUDACC__
x = blockDim.x;
#endif
return x;
Well it’s true this question has been asked before (defines, automatically defined by NVCC?), and the answer was NO; but I’m still convinced that somehow it must be possible. I’ve now tried CUDACC,WIN32, and CUDAFE, plus my own macros with -D and -U, here and there, before and after -Xcompiler, but with no luck.
Surely there’s a way. Perhaps a sneaky undocumented macro that pops up just at the right moment?
A single function, with one name, can accept device and host together, so why truly can’t this be done?
Thanks, but unfortunately CUDABE is the same as the others. If I test there that it is defined, it compiles (because it’s not defined). Then when I run the program, the results show that the conditional section has been omitted.
Paul
I do this and it works fine. I just pass a preprocessor define to nvcc using -D. I use the command line nvcc.exe -cubin -DMYPREPROC …
I am using the driver API so maybe it won’t work with the runtime API?
EDIT: I should also mention that in my code I don’t use blockDim or host, device. Maybe there is a problem there.
I’m not using the driver API, so I can’t comment there; it’s not an option for me in any case. And I also define my own macros like that. But yes, it’s the built-in variables which are the problem - with non-emulator builds anyway.
