It appears that when 32-bit host code in the presence of a 64-bit CUDA driver, the runtime incorrectly reports the driver version from a call to [font=“Courier New”]cudaDriverGetVersion()[/font], which seems to cause a runtime error in my application, “CUDA driver version is insufficient for CUDA runtime version.”
My test environment is a 64-bit CentOS 5 Linux workstation with the 64-bit CUDA driver v256.25 and the 3.1 beta toolkit. I am attaching a small test application, which may be compiled with GNU make/gcc to demonstrate the problem.
/* Save this code in a file named "driver_version.c"
* Compile with GNU make:
* % make driver_version CFLAGS="-DCUDART_LIBRARY=libcudart.so -I/usr/local/cuda/include" LDLIBS="-ldl" -f/dev/null
* Changing the architecture options causes different behaviour. With a 64-bit executable, the results are as expected:
* % rm driver_version; make driver_version TARGET_ARCH=-m64 CFLAGS="-DCUDART_LIBRARY=libcudart.so -I/usr/local/cuda/include" LDLIBS="-ldl" -f/dev/null
* % ./driver_version
* > CUDA driver v3010 runtime v3010
* With a 32-bit executable, the driver version is reported incorrectly:
* > CUDA driver v8334885 runtime v3010
#include <stdlib.h>
#include <stdio.h>
#include <dlfcn.h>
#include <cuda_runtime_api.h>
#ifndef CUDART_LIBRARY
#error Must define CUDART_LIBRARY (e.g. -DCUDART_LIBRARY=libcudart.so or -DCUDART_LIBRARY=libcudart.dylib)
#endif
#define Q_(IT) #IT
#define Q(IT) Q_(IT)
typedef cudaError_t (*cudaDriverGetVersion_f)(int *);
typedef cudaError_t (*cudaRuntimeGetVersion_f)(int *);
int main (int argc, char **argv) {
const char* dll = Q(CUDART_LIBRARY);
void *cudaRT = NULL;
cudaDriverGetVersion_f cudaDriverGetVersion = NULL;
cudaRuntimeGetVersion_f cudaRuntimeGetVersion = NULL;
cudaRT = dlopen(dll, RTLD_NOW);
if (!cudaRT) return 1;
cudaDriverGetVersion = (cudaDriverGetVersion_f)dlsym(cudaRT, "cudaDriverGetVersion");
cudaRuntimeGetVersion = (cudaRuntimeGetVersion_f)dlsym(cudaRT, "cudaRuntimeGetVersion");
int vdriver, vruntime;
cudaDriverGetVersion(&vdriver);
cudaRuntimeGetVersion(&vruntime);
fprintf(stderr, "CUDA driver v%d runtime v%d\n", vdriver, vruntime);
return 0;
