cudaGetDeviceCount
System is the NVIDIA AGX unbuntu 18.04
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Feb_28_22:34:44_PST_2021
Cuda compilation tools, release 10.2, V10.2.300
Build cuda_10.2_r440.TC440_70.29663091_0
I am trying to run the simpleCUFFT but I get this error:
/usr/local/cuda-11.3/samples/7_CUDALibraries/simpleCUFFT$ ./simpleCUFFT
[simpleCUFFT] is starting…
CUDA error at …/…/common/inc/helper_cuda.h:779 code=999(cudaErrorUnknown) “cudaGetDeviceCount(&device_count)”
From deviceQuery I get
usr/local/cuda-11.3/samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 999
→ unknown error
Result = FAIL
If you want to use CUDA 11, please reflash your device with JetPack 5.
There are some dependencies between GPU driver and libraries, r35 is required for the CUDA 11.
