I have installed CUDA 11.2 and I have Visual Studio 2019 Community Edition.
For your information on my CUDA version, nvcc -V returns:
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Feb_14_22:08:44_Pacific_Standard_Time_2021
Cuda compilation tools, release 11.2, V11.2.152
Build cuda_11.2.r11.2/compiler.29618528_0
The CUDA Wizard works fine, and I have successfully run the QueryDeviceDrv sample, with the following return:
CUDA Device Query (Driver API) statically linked version
Detected 1 CUDA Capable device(s)
Device 0: “Quadro K3100M”
CUDA Driver Version: 10.1
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 4096 MBytes (4294967296 bytes)
( 4) Multiprocessors, (192) CUDA Cores/MP: 768 CUDA Cores
GPU Max Clock rate: 706 MHz (0.71 GHz)
Memory Clock rate: 1600 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Max Texture Dimension Sizes 1D=(65536) 2D=(65536, 65536) 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Texture alignment: 512 bytes
Maximum memory pitch: 2147483647 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: No
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Result = PASS
However, when I run the QueryDevice sample, there is a crash at line 61 of deviceQuery.cpp:
cudaError_t error_id = cudaGetDeviceCount(&deviceCount);
The cudaGetDeviceCount returns error 3 (cudaErrorInitializationError) and devicecount equals zero.
I am stuck on this error, and I would greatly appreciate if you could help me to understand its cause and how to solve it.
Many thanks by advance.
