CUDA Toolkit v12.0 failed to compile every sample with .cu files on Windows 10 and Visual Studio 2022
Build started…
1>------ Build started: Project: bandwidthTest, Configuration: Debug x64 ------
1>Compiling CUDA source file bandwidthTest.cu…
1>
1>D:\CUDA\v12.0\cuda-samples-12.0\Samples\1_Utilities\bandwidthTest>“D:\CUDA\v12.0\bin\nvcc.exe” -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" -gencode=arch=compute_80,code="sm_80,compute_80" -gencode=arch=compute_86,code="sm_86,compute_86" -gencode=arch=compute_90,code="sm_90,compute_90" --use-local-env -ccbin “D:\VS\2022\Professional\VC\Tools\MSVC\14.34.31933\bin\HostX64\x64” -x cu -I./ -I…/…/…/Common -I./ -ID:\CUDA\v12.0/include -I…/…/…/Common -I"D:\git\vcpkg\installed\x64-windows\include" -ID:\CUDA\v12.0\include -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” --threads 0 -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -Xcompiler “/Fdx64/Debug/vc143.pdb” -o D:\CUDA\v12.0\cuda-samples-12.0\Samples\1_Utilities\bandwidthTest\x64\Debug\bandwidthTest.cu.obj “D:\CUDA\v12.0\cuda-samples-12.0\Samples\1_Utilities\bandwidthTest\bandwidthTest.cu”
1>D:\VS\2022\Professional\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.0.targets(799,9): error MSB3721: The command ““D:\CUDA\v12.0\bin\nvcc.exe” -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" -gencode=arch=compute_80,code="sm_80,compute_80" -gencode=arch=compute_86,code="sm_86,compute_86" -gencode=arch=compute_90,code="sm_90,compute_90" --use-local-env -ccbin “D:\VS\2022\Professional\VC\Tools\MSVC\14.34.31933\bin\HostX64\x64” -x cu -I./ -I…/…/…/Common -I./ -ID:\CUDA\v12.0/include -I…/…/…/Common -I"D:\git\vcpkg\installed\x64-windows\include” -ID:\CUDA\v12.0\include -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” --threads 0 -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -Xcompiler “/Fdx64/Debug/vc143.pdb” -o D:\CUDA\v12.0\cuda-samples-12.0\Samples\1_Utilities\bandwidthTest\x64\Debug\bandwidthTest.cu.obj “D:\CUDA\v12.0\cuda-samples-12.0\Samples\1_Utilities\bandwidthTest\bandwidthTest.cu”” exited with code 1.
1>Done building project “bandwidthTest_vs2022.vcxproj” – FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Elapsed 00:04.075 ==========
==> If your try to reproduce the compilation using nvcc in the command prompt, nothing happens.
==> It’s happening since previous version of CUDA Toolkit (v10.x, v11.x), now I’m sharing here at forum
==> deviceQuery works because is C++ only - don’t use nvcc
==> Anyone has similar problem?
D:\CUDA\v12.0\cuda-samples-12.0\bin\win64\Debug\deviceQuery.exe Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “NVIDIA GeForce RTX 2060”
CUDA Driver Version / Runtime Version 12.0 / 12.0
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 6144 MBytes (6442123264 bytes)
(030) Multiprocessors, (064) CUDA Cores/MP: 1920 CUDA Cores
GPU Max Clock rate: 1680 MHz (1.68 GHz)
Memory Clock rate: 7001 Mhz
Memory Bus Width: 192-bit
L2 Cache Size: 3145728 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 65536 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 6 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.0, CUDA Runtime Version = 12.0, NumDevs = 1
Result = PASS
I’ve solved the problem. Changing my TEMP and TMP variables to a path without spaces (my user name from %USERPROFILE%).
My old TEMP and TMP variables were:
TEMP = %USERPROFILE%\AppData\Local\Temp
TMP = %USERPROFILE%\AppData\Local\Temp
I’ve changed to:
TMP=D:\Temp\Local\Temp
TEMP=D:\Temp\Local\Temp
Now, working with Visual Studio 2022.
It’s an issue on NVIDIA CUDA Toolkit to Windows.
Should be documented, as least, as workaround.
