I installed the CUDA SDK and toolkit, taking special care that kext was enabled, set the environment variables on bash_profile and restarted my MacBook Pro. After I restarted, I tried some of the examples. To my satisfaction, the deviceQuery worked fine. But some of the examples failed stating ‘There is no device supporting CUDA’ , while some fail with ‘bus error’ . So, I reinstalled the toolkit, again making sure the kext is checked, and restarted again. But the examples still don’t run.
[codebox]me@mymachine $ ./deviceQuery
There is 1 device supporting CUDA
Device 0: “GeForce 8600M GT”
Major revision number: 65536
Minor revision number: 1
Total amount of global memory: 268238848 bytes
Total amount of constant memory: 337500 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1 kilohertz
Test PASSED
Error when parsing command line argument string.
Press ENTER to exit…
me@mymachine $ ./simpleCUFFT
There is no device supporting CUDA.
me@mymachine $ ./dwtHaar1D
me@mymachine $ ./cppIntegration
me@mymachine $ ./boxFilter
Bus error
me@mymachine $ ./imageDenoising
Allocating host and CUDA memory and loading image file…
Bus error[/codebox]
My specs are as follows :
Mac Book Pro - OSX 10.5.5
8600M GT
me@mymachine $ nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2007 NVIDIA Corporation
Built on Wed_Jul_16_12:14:50_PDT_2008
Cuda compilation tools, release 2.0, V0.2.1221
Please help me get this up and running.
Thanks,
Sahil
