cudaImportExternalMemory return cudaErrorIllegalAddress
I’m trying to import a directx textures in cuda, this textures are created by Unreal.
For some exotic resolution cudaImportExternalMemory return cudaErrorIllegalAddress
for the second texture recieved.
Info:
the texture are created once and never destroyed.
My code is:
struct DX12TexData
	unsigned int uniqueId = 0;	// data unique identifier
	void* handle;				// directx 12 texture handle
	ID3D12Resource* resource;	// directx 12 texture resource
	unsigned long long memSize; // texure memory size in bytes
	unsigned long long rowPitch;// row pitch in bytes
	unsigned long long rowSize;	// row size in bytes
struct CudaMemory
	void* m_cudaMem = nullptr;
	size_t m_memSize = 0;
	size_t m_rowPitch = 0;
	size_t m_rowSize = 0;
	bool m_isReallocated = false;
	explicit operator bool()const
		return m_cudaMem != nullptr;
struct CudaMappedMemory : CudaMemory
	void* handle = nullptr;
	cudaExternalMemory_t mappedMemory = nullptr;
std::unordered_map<unsigned int, CudaMappedMemory> m_externFloat16;
bool createExternalMemory(const DX12TexData& d3d12Texture)
	cudaExternalMemoryHandleDesc memDesc{};
	memset(&memDesc, 0, sizeof(memDesc));
	memDesc.type = cudaExternalMemoryHandleTypeD3D12Resource;
	memDesc.handle.win32.handle = d3d12Texture.handle;
	memDesc.size = d3d12Texture.memSize;
	memDesc.flags = cudaExternalMemoryDedicated;
	m_externFloat16[d3d12Texture.uniqueId].handle = d3d12Texture.handle;
	const cudaError_t cudaError = cudaImportExternalMemory(&m_externFloat16[d3d12Texture.uniqueId].mappedMemory, &memDesc);
	if (cudaError != cudaSuccess)
		OptroLogger::Error(CURRENT_SOURCES_LOCATION, "cuda error [cudaImportExternalMemory]: %s", cudaGetErrorName(cudaError));
		return false;
	return true;
In 800x800 OK
In 1024x1024 OK
In 600x600 OK
In 900x900 KO
In 904x904 KO
In 500x500 KO
Do you have any idea ?
thanks.
