When I am doing :
[codebox]
float** tab;
size_t pitch;
int width, height;
cudaMallocPitch((void**)tab, &pitch, width*sizeof(float),height);
[/codebox]
I’ve got a segmentation fault.
but when I do :
[codebox]
float* tab;
size_t pitch;
int width, height;
cudaMallocPitch((void**)&tab, &pitch, width*sizeof(float),height);
[/codebox]
The segfault disappear.
The matter is that I’d like to use a 2D tab to get the result of tex2D. Do you know what’s wrong in the first case and how I can keep the float** ?
cudaMallocPitch is expecting the address of a pointer, which it uses to write the value of the pointer to the newly allocated device memory. In the first case you’re passing “tab”, which has not been initialized.
I would recommend reading this:
[url=“http://www.amazon.co.uk/C-Programming-Language-2nd/dp/0131103628”]http://www.amazon.co.uk/C-Programming-Lang...d/dp/0131103628[/url]
Ok , I missread the cuda Programming Guide 2.1 pp. 34 & 35 . And I didn’t use my brain, i “recopy” it stupidly.
Sorry to bother you.
