I am trying to copy the pixel data from a pbo to host memory using cudamemcpy. I am not having success…Perhaps I am not understanding cuda/gl interoperability enough.
Prior to render I init pbo and register with cuda
glGenBuffersARB(PBO_COUNT, &pboId);
glBindBufferARB(GL_PIXEL_PACK_BUFFER_ARB, pboId);
glBufferDataARB(GL_PIXEL_PACK_BUFFER_ARB, DATA_SIZE, 0, GL_STREAM_READ_ARB);
cudaGLRegisterBufferObject( pboId );
glBindBufferARB(GL_PIXEL_PACK_BUFFER_ARB, 0);
…and Allocate host memory:
cudaMallocHost( (void **) & pHostMemory, DATA_SIZE);
In render loop
render scene
then I copy frame buffer back via pbo
glReadPixels(0, 0, SCREEN_WIDTH, SCREEN_HEIGHT, PIXEL_FORMAT, GL_UNSIGNED_BYTE, 0);
copy pbo data from device to host
uchar4 *dptr;
cudaGLMapBufferObject((void**)&dptr, pboIds[nextIndex]);
cudaMemcpy(pHostMemory, dptr, NBYTES, cudaMemcpyDeviceToHost);
cudaGLUnmapBufferObject(pboId);
Is this correct? After the call to cudaGLMapBufferObject, what is dptr really pointing to? Is it pointing to the same memory as src in this case?
GLubyte* src = (GLubyte*)glMapBufferARB(GL_PIXEL_PACK_BUFFER_ARB, GL_READ_ONLY_ARB);
if(src)
// mod data
glUnmapBufferARB(GL_PIXEL_PACK_BUFFER_ARB); // release pointer to the mapped buffer
CD
