is there a way to directly P2P DMA into a GL Texture Buffer, without the need to cudaMemcpy?
regards
Ben
regards
Ben
Using CUDA? There is not.
Are there any ways you can imagine, which could be used to reduce memcopies? Basically now I have 2 copies
Is there a way to use eglimagekhr or something to do a direct p2p memory?
There might be, and in that case that is not a CUDA question, and you are asking in the wrong place. I don’t know the correct forum offhand for that question.
Using CUDA and OpenGL, the method I know of is to start with a GL resource (such as a PBO) and map it into CUDA space using CUDA/OpenGL interop, for which there are sample codes showing how. There is then no need to cudaMemcpy anything into a GL Pixel buffer (your 2nd bullet). Whether or not you can DMA into such a buffer, I don’t know. Based on the “P2P DMA” I am somewhat familiar with (GPUDirect RDMA), my guess would be no. GPUDirect RDMA generally requires a buffer acquired using the defined method. I won’t be able to provide detailed assistance here, and its not even clear to me what you are doing. Your usage of “P2P DMA” suggest to me transfer of data from a 3rd party device (i.e. not a CUDA GPU). But maybe you mean something else.
