I am trying to learn Cuda. I have the following code,
global void DivideByPivot(float *d_m, float pivot, int N)
int j = blockIdx.x * blockDim.x + threadIdx.x;
if (j < N) d_m[j] /= pivot;
I want to read back the value in d_m[7] from the device. Do I have to use cudaMemcpy to do that?
How can I then assign d_m[7] = 1.0 Do I have to do cudaMemcpy again?
Is there a simpler way to read and write a single value from and to the device memory?
I don’t need to read back the whole array. I need to read back only a single value from the device like x = d_m[7].
I also want to write to a single position on the device like d_m[7] = x; Do I need to call cudaMemcpy for these?
this would copy the a_device Array from gpumemory to hostmemory. the size is defined by for example MEMSize = 10 * sizeof(float)
for an float array with 10 elements.
but i dont really get it what you want to do, and why!
You only need cudaMemcpy when transferring data from Device to Host or vice versa.
once your data is on the device you can acces and edit it. just by indexing!
d_Gs is a device memory area. I want to read a single value to a variable called pivot. I also want to write a value to a single device location d_Gs[ind + icol] = 1.0;
