How to copy a single variable from device to host?
This is what I want to do:
  1. declare a device variable:
    device float a;
  2. write a kernel with the last value to be returned
    global kernerl()
    a= sometthing;
  3. in the main calling program
//declare a host variable
float b;
kernel<<< …>>> ();
// try to get the variable back to host memory
cudaMemcpy ( b, a, sizeof(float) , cudaMemcpyDeviceToHost ); → this does not work
cudaMemcpyFromSymbol( b , a , sizeof(float), 0, cudaMemcpyDeviceToHost); → this does not work
b = a; → this does not work
What else is there?
I think that you have to cudaMalloc space for the variable (it would be a 1-element array, effectively). I don’t think (perhaps I’m wrong…) that you can have device variables with file scope.
Ooops, I just had a wrong printf arguments looking at the wrong variables. Yes you can have device variable file scope and you don’t have to cudaMalloc a single variable.
Now everything works.
