cudaMemcpy2D: What's wrong in this code?
Hi everybody
I’m trying to pass a 2D matrix of 0’s to device to calculate in the gpu a simple operation:
for example if I have a matrix[height][width] where heigh = 2 an width = 2
matrix[0][0] = 0
matrix[0][1] = 1
matrix[1][0] = 2
matrix[1][1] = 3
Finally I want copy the results from device to host and print results. The code works fine if height = widht, but it doesn’t work if height != width
Any Ideas?
Thank you. I’m desperate :(
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include <curand_kernel.h>
__global__ void MyKernel(float** dev_matrix, size_t pitch, int width, int height)
	int number = 0;
	for (int i = 0; i < height; ++i)
		float* row = (float*)((char*)dev_matrix + i*pitch);
		for (int j = 0; j < width; ++j)
			row[j] = number;
			number++;
int main (int argc , char * argv [])
	int width = 4, height = 2, i, j;
	float matrix[width][height];
	float **dev_matrix;
	size_t pitch;
printf("\nMATRIX MANIPULATION\n");
	for (i = 0; i < height; i++)
		for (j = 0; j < width; j++)
			matrix[i][j] = 0.0;
	printf("Matrix in host memory\n");
			printf("%f   ", matrix[i][j]);
		printf("\n");
	cudaMallocPitch(&dev_matrix, &pitch, width * sizeof(float), height);
	cudaMemcpy2D(dev_matrix, pitch, matrix, width * sizeof(float), width * sizeof(float), height, cudaMemcpyHostToDevice);
	MyKernel<<<1, 1>>>(dev_matrix, pitch, width, height);
	cudaMemcpy2D(matrix, width * sizeof(float), dev_matrix, pitch, width * sizeof(float), height, cudaMemcpyDeviceToHost);
	printf("Matrix after calculate elements in the gpu\n");
		printf("\n");
cudaFree(dev_matrix);
	return 0;
any ideas?
If you want to move only 0’s to the device you do not need a memory copy operation, you need a memory set operation, which is much faster.
If you are 100% sure each element is processed you do not even need a memory set operation, the allocation is just enough, since you write the output of every element.
About memCpy2D i cannot help because I never used 2D and 3D before since the same can be realized with simple memCpy and an array of pointer pointing to the individual rows
Thank you for the reply
This is an example. In the real code I move random numbers from the host to device.
I think the problem is in the CudaMemcpy2D. More ideas, please?
but
                        matrix[i][j] = 0.0;
                printf("\n");
I think you need to reverse your width and height in the loop or in the declaration
Oh my god…thank you so much.
English is not my languaje, and I’ve confused wiht width and height.
Thanks again!
