I tried to use Asynchronous 2d data transfer in CUDA Fortran. Even though it does not give neither compile-time nor run-time error, the code did not give the expected results. For comparison I have sent both asynchronous and synchronous code. I could not find the problem, could you help?
cuda02.zip (2.2 KB)
cuda03.zip (2.0 KB)
cuda02 is asynchronous, cuda03 is normal.
! Expected result !
81.30000000000001 162.6000000000000 243.9000000000000
Is cudaMemcpy2DAsyn available for Fortran?
Yunus,
Thank you.
