Now I want to verify the installation, but it seems like the installation guide still does not update their documents, it seems like the verifying method is only for 7.0, because I do not see there is a /usr/src/cudnn_samples_v7 after installation.
My computer:
Ubuntu 16.04
Nvidia 390.25
CUDA9.1
Download runtime debian cuDNN 7.1(the most recently update version)
To verify that cuDNN is installed and is running properly, compile the mnistCUDNN sample located in the /usr/src/cudnn_samples_v7 directory in the debian file.
Copy the cuDNN sample to a writable path.
$cp -r /usr/src/cudnn_samples_v7/ $HOME
Go to the writable path.
$ cd $HOME/cudnn_samples_v7/mnistCUDNN
Compile the mnistCUDNN sample.
$make clean && make
Run the mnistCUDNN sample.
$ ./mnistCUDNN
If cuDNN is properly installed and running on your Linux system, you will see a message similar to the following:
Thank you, but actually I saw these instructions after I install the cuDNN7.1.
Rather, my question is different. Sorry for the misunderstanding.
Since I follow the instructions to install but can not find /usr/src/cudnn_samples_v7, thus I ask here what is the method to verify correctness. The installation is super easy with just single command dpkg, I can not image where I did wrong. I prefer to believe I did correctly but the updates have problem.
Mixed dnn version. The header is version 7301 while the library is version 7104.
can any one help ,me understand what is this header version 7301 mean and how do i solve this
thanks in advance
