CudNN 8.6.0 installation issue (ubuntu 20.04 - arm64 architecture)
I am trying to install CuDNN version 8.6.0 , where i am having issue running
sudo dpkg -i cudnn-local-repo-ubuntu2004-8.6.0.163_1.0-1_arm64.deb
My system is a
ubuntu 20.04
Cuda 11.4 (already installed)
aarch64 - ($ uname -m) -> hence went for arm64.deb download
I downloaded the cudnn-local-repo-ubuntu2004-8.6.0.163_1.0-1_arm64.deb
------which then prompted to run the key
~/tk_ws$ sudo dpkg -i cudnn-local-repo-ubuntu2004-8.6.0.163_1.0-1_arm64.deb
Selecting previously unselected package cudnn-local-repo-ubuntu2004-8.6.0.163.
(Reading database ... 181126 files and directories currently installed.)
Preparing to unpack cudnn-local-repo-ubuntu2004-8.6.0.163_1.0-1_arm64.deb ...
Unpacking cudnn-local-repo-ubuntu2004-8.6.0.163 (1.0-1) ...
Setting up cudnn-local-repo-ubuntu2004-8.6.0.163 (1.0-1) ...
The public cudnn-local-repo-ubuntu2004-8.6.0.163 GPG key does not appear to be installed.
To install the key, run this command:
sudo cp /var/cudnn-local-repo-ubuntu2004-8.6.0.163/cudnn-local-04A93B30-keyring.gpg /usr/share/keyrings/
-----I did run,
-----then reran the
------but it doesnot look like properly installed.
------with some research , also did run the following command, which worked for most people.
------ but unfortunately did not work for me.
sudo cp /var/cudnn-local-repo-ubuntu2004-8.6.0.163/cudnn-local-04A93B30-keyring.gpg /usr/share/keyrings/cuda-archive-keyring.gpg
Seeking for help.
Regards.
Hi @karishmathumu ,
I would recommend you to follow the steps from the document.
Please let us know if you still face the issue.
It is working now.
Thank you
