hi SivaRamaKrishna,
My complete TRT sample:
#include "NvInfer.h"
#include "cuda_runtime_api.h"
#include <cassert>
#include <string>
#include <fstream>
#include <iostream>
#include <sstream>
using namespace nvinfer1;
// Logger for TensorRT info/warning/errors
class Logger : public nvinfer1::ILogger
public:
Logger(): Logger(Severity::kWARNING) {}
Logger(Severity severity): reportableSeverity(severity) {}
void log(Severity severity, const char* msg) override
// suppress messages with severity enum value greater than the reportable
if (severity > reportableSeverity) return;
switch (severity)
case Severity::kINTERNAL_ERROR: std::cerr << "INTERNAL_ERROR: "; break;
case Severity::kERROR: std::cerr << "ERROR: "; break;
case Severity::kWARNING: std::cerr << "WARNING: "; break;
case Severity::kINFO: std::cerr << "INFO: "; break;
default: std::cerr << "UNKNOWN: "; break;
std::cerr << msg << std::endl;
Severity reportableSeverity{Severity::kWARNING};
static Logger gLogger;
void displayITensorShape(ITensor* tensor, std::string name)
std::cout << name<<": ";
Dims dims = tensor->getDimensions();
for(int k = 0; k < dims.nbDims; ++k){
std::cout<<dims.d[k]<<"*";
std::cout<< std::endl;
ICudaEngine* createNetworkEngine(unsigned int maxBatchSize, IBuilder* builder, DataType data_type)
INetworkDefinition* network = builder->createNetwork();
// Dims4: ERROR: cudnnPoolingLayer.cpp (130) - Cudnn Error in execute: 3
ITensor* data_input = network->addInput("data", data_type, Dims4{1, 3, 4, 8});
// Dims3: successful
//ITensor* data_input = network->addInput("data", data_type, Dims3{3, 4, 8});
assert(data_input);
IPoolingLayer* pool = network->addPooling(*data_input, PoolingType::kMAX, DimsHW{2, 2});
assert(pool);
pool->setStride(DimsHW{2, 2});
//pool->setPadding(DimsHW{1, 1});
pool->setName("pool");
ILayer* output = pool;
output->getOutput(0)->setName("test_pool");
network->markOutput(*output->getOutput(0));
output->getOutput(0)->setType(DataType::kFLOAT);
displayITensorShape(data_input, "input shape");
displayITensorShape(output->getOutput(0), "output shape");
// Build engine
std::cout << "****** building network ***********" << std::endl;
builder->setMaxBatchSize(1);
builder->setMaxWorkspaceSize(1 << 20);
//builder->setAverageFindIterations(1);
//builder->setMinFindIterations(1);
//builder->setDebugSync(true);
std::cout <<"MaxWorkspaceSize: " << builder->getMaxWorkspaceSize() << std::endl;
ICudaEngine* engine = builder->buildCudaEngine(*network);
std::cout << "build newwork finsih" << std::endl;
network->destroy();
return engine;
void APIToModel(int maxBatchSize, const char* plan_file)
cudaSetDevice(0);
IHostMemory* modelStream{nullptr};
IBuilder* builder = createInferBuilder(gLogger);
// Create model to populate the network, then set the outputs and create an engine
ICudaEngine* engine = createNetworkEngine(maxBatchSize, builder, DataType::kFLOAT);
assert(engine != nullptr);
modelStream = engine->serialize();
// Serialize the engine
if(plan_file){
std::stringstream gieModelStream;
gieModelStream.seekg(0, gieModelStream.beg);
gieModelStream.write((const char*)modelStream->data(), modelStream->size());
std::ofstream outFile;
outFile.open(plan_file);
outFile << gieModelStream.rdbuf();
outFile.close();
modelStream->destroy();
// Close everything down
engine->destroy();
builder->destroy();
int main(int argc, char** argv)
int maxBatchSize = 1;
std::string plan_file = "./model_trt_test_pool.plan";
APIToModel(maxBatchSize, plan_file.c_str());
std::cout << "FINISH: " << plan_file << std::endl;
return 1;
line 52: input shape is Dims4
line 54: input shape is Dims3
I can reproduce this issue as follows:
- run the following commond line to generate test_pool file:
sudo g++ build_trt_test_pool.cpp -std=c++11 -L/usr/local/cuda/lib64 -lcudart -L/usr/lib/aarch64-linux-gnu/ -lnvinfer -I/usr/local/cuda/include -o test_pool
- run the test_pool file:
sudo ./test_pool
when the input shape is Dime3(line54), success!!!, log:
input shape: 3*4*8*
output shape: 3*2*4*
MaxWorkspaceSize: 1048576
FINISH: ./model_trt_test_pool.plan
when the input shape is Dime4(line52), failed!!!, log:
input shape: 1*3*4*8*
output shape: 1*3*2*4*
test_pool: build_trt_test_pool.cpp:97: void APIToModel(int, const char*): Assertion `engine != nullptr' failed.
Aborted (core dumped)
thanks!!!
