update:
the issue is not concat. it’s the padding params used in following pooling layer. remove the padding parameter works can pass this layer.
layer {
type: “Pooling”
bottom: “conv6/bn”
top: “3A/p4_pool”
pooling_param {
pool: AVE
kernel_size: 3
pad: 1
input shape (1, 288, 35 ,35)
run tensorrt with ngc docker 17.12.
model from NVCaffe’s inception_v3.
Issue
can’t handle the concat layer:
to reproduce:
giexec --deploy=deploy.prototxt --batch=1 --output=3A/concat
deploy: deploy.prototxt
batch: 1
output: 3A/concat
Input “data”: 3x299x299
Output “3A/concat”: 288x35x35
giexec: cudnnBuilder2.cpp:165: nvinfer1::builder::Format::Type nvinfer1::builder::supportedFormats(const nvinfer1::builder::Node&, nvinfer1::builder::Format::Type, const nvinfer1::cudnn::HardwareContext&): Assertion `result’ failed.
Aborted (core dumped)
