Hi there,
I am currently trying to run a Neural Network using TensorFlow:
import tensorflow as tf
import numpy as np
tf_config = tf.ConfigProto()
tf_config.gpu_options.allow_growth = True
tf_sess = tf.Session(config=tf_config)
tf.import_graph_def(trt_graph, name='')
output_tensor_name = 'reshape_5/Reshape' + ":0"
output_tensor = tf_sess.graph.get_tensor_by_name(output_tensor_name)
print("input_tensor_name: {}\noutput_tensor_name: {}".format(
input_tensor_name, output_tensor_name))
feed_dict = {
input_tensor_name: [np.load("testdata.npy")]
preds = tf_sess.run(output_tensor, feed_dict)
However I am getting the following error message on the last line:
UnknownError Traceback (most recent call last)
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in _do_call(self, fn, *args)
1355 try:
-> 1356 return fn(*args)
1357 except errors.OpError as e:
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in _run_fn(feed_dict, fetch_list, target_list, options, run_metadata)
1340 return self._call_tf_sessionrun(
-> 1341 options, feed_dict, fetch_list, target_list, run_metadata)
1342
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in _call_tf_sessionrun(self, options, feed_dict, fetch_list, target_list, run_metadata)
1428 self._session, options, feed_dict, fetch_list, target_list,
-> 1429 run_metadata)
1430
UnknownError: 2 root error(s) found.
(0) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above.
[[{{node conv2d_4/Conv2D}}]]
(1) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above.
[[reshape_5/Reshape/_3]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
<ipython-input-8-6a3d47810bf6> in <module>
9 input_tensor_name: [np.load("testdata.npy")]
10 }
---> 11 preds = tf_sess.run(output_tensor, feed_dict)
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in run(self, fetches, feed_dict, options, run_metadata)
948 try:
949 result = self._run(None, fetches, feed_dict, options_ptr,
--> 950 run_metadata_ptr)
951 if run_metadata:
952 proto_data = tf_session.TF_GetBuffer(run_metadata_ptr)
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in _run(self, handle, fetches, feed_dict, options, run_metadata)
1171 if final_fetches or final_targets or (handle and feed_dict_tensor):
1172 results = self._do_run(handle, final_targets, final_fetches,
-> 1173 feed_dict_tensor, options, run_metadata)
1174 else:
1175 results = []
/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py in _do_run(self, handle, target_list, fetch_list, feed_dict, options, run_metadata)
1348 if handle is None:
1349 return self._do_call(_run_fn, feeds, fetches, targets, options,
-> 1350 run_metadata)
1351 else:
1352 return self._do_call(_prun_fn, handle, feeds, fetches)
1368 pass
1369 message = error_interpolation.interpolate(message, self._graph)
-> 1370 raise type(e)(node_def, op, message)
1371
1372 def _extend_graph(self):
[[node conv2d_4/Conv2D (defined at <ipython-input-5-a4f50148c90c>:4) ]]
Original stack trace for 'conv2d_4/Conv2D':
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.6/dist-packages/ipykernel_launcher.py", line 16, in <module>
app.launch_new_instance()
File "/usr/local/lib/python3.6/dist-packages/traitlets/config/application.py", line 658, in launch_instance
app.start()
File "/usr/local/lib/python3.6/dist-packages/ipykernel/kernelapp.py", line 563, in start
self.io_loop.start()
File "/usr/local/lib/python3.6/dist-packages/tornado/platform/asyncio.py", line 148, in start
self.asyncio_loop.run_forever()
File "/usr/lib/python3.6/asyncio/base_events.py", line 438, in run_forever
self._run_once()
File "/usr/lib/python3.6/asyncio/base_events.py", line 1451, in _run_once
handle._run()
File "/usr/lib/python3.6/asyncio/events.py", line 145, in _run
self._callback(*self._args)
File "/usr/local/lib/python3.6/dist-packages/tornado/ioloop.py", line 690, in <lambda>
lambda f: self._run_callback(functools.partial(callback, future))
File "/usr/local/lib/python3.6/dist-packages/tornado/ioloop.py", line 743, in _run_callback
ret = callback()
File "/usr/local/lib/python3.6/dist-packages/tornado/gen.py", line 787, in inner
self.run()
File "/usr/local/lib/python3.6/dist-packages/tornado/gen.py", line 748, in run
yielded = self.gen.send(value)
File "/usr/local/lib/python3.6/dist-packages/ipykernel/kernelbase.py", line 365, in process_one
yield gen.maybe_future(dispatch(*args))
File "/usr/local/lib/python3.6/dist-packages/tornado/gen.py", line 209, in wrapper
yielded = next(result)
File "/usr/local/lib/python3.6/dist-packages/ipykernel/kernelbase.py", line 272, in dispatch_shell
yield gen.maybe_future(handler(stream, idents, msg))
File "/usr/local/lib/python3.6/dist-packages/ipykernel/kernelbase.py", line 542, in execute_request
user_expressions, allow_stdin,
File "/usr/local/lib/python3.6/dist-packages/ipykernel/ipkernel.py", line 294, in do_execute
res = shell.run_cell(code, store_history=store_history, silent=silent)
File "/usr/local/lib/python3.6/dist-packages/ipykernel/zmqshell.py", line 536, in run_cell
return super(ZMQInteractiveShell, self).run_cell(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py", line 2855, in run_cell
raw_cell, store_history, silent, shell_futures)
File "/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py", line 2881, in _run_cell
return runner(coro)
File "/usr/local/lib/python3.6/dist-packages/IPython/core/async_helpers.py", line 68, in _pseudo_sync_runner
coro.send(None)
File "/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py", line 3058, in run_cell_async
interactivity=interactivity, compiler=compiler, result=result)
File "/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py", line 3249, in run_ast_nodes
if (await self.run_code(code, result, async_=asy)):
File "/usr/local/lib/python3.6/dist-packages/IPython/core/interactiveshell.py", line 3326, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File "<ipython-input-5-a4f50148c90c>", line 4, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 443, in import_graph_def
_ProcessNewOps(graph)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 236, in _ProcessNewOps
for new_op in graph._add_new_tf_operations(compute_devices=False): # pylint: disable=protected-access
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 3751, in _add_new_tf_operations
for c_op in c_api_util.new_tf_operations(self)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 3751, in <listcomp>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 3641, in _create_op_from_tf_operation
ret = Operation(c_op, self)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 2005, in __init__
self._traceback = tf_stack.extract_stack()
Notes:
Tensorflow Version 1.14.0
Cuda Version 10.0
