I’m trying to get the Simple Audio Recognition Tutorial by Tensorflow working on the Jetson Nano. (https://www.tensorflow.org/tutorials/sequences/audio_recognition)
The problem already starts in the first line when running the train.py.
After downloading the dataset, several problems occur:
I also set the $path & $LD_LIBRARY_PATH
Is there a way to upgrade the cudnn Version for the jetson nano or is it limited to released jetpack versions by Nvidia? I also read that the cudnn Versions for the jetson nano differ to desktop versions.
If it is not possible, is there another easy way to get started with speech recognition on the jetson nano?
Full Terminalfeedback:
$ python3 tensorflow/examples/speech_commands/train.py
2019-08-20 13:50:53.590602: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
^[/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
2019-08-20 13:51:10.441541: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2019-08-20 13:51:10.442307: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x2f87a900 executing computations on platform Host. Devices:
2019-08-20 13:51:10.442381: I tensorflow/compiler/xla/service/service.cc:175] StreamExecutor device (0): <undefined>, <undefined>
2019-08-20 13:51:10.746295: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcuda.so.1
2019-08-20 13:51:11.020507: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:11.020820: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x3100ed10 executing computations on platform CUDA. Devices:
2019-08-20 13:51:11.020879: I tensorflow/compiler/xla/service/service.cc:175] StreamExecutor device (0): NVIDIA Tegra X1, Compute Capability 5.3
2019-08-20 13:51:11.021403: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:11.021536: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1640] Found device 0 with properties:
name: NVIDIA Tegra X1 major: 5 minor: 3 memoryClockRate(GHz): 0.9216
pciBusID: 0000:00:00.0
2019-08-20 13:51:11.021626: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-08-20 13:51:11.161753: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-08-20 13:51:11.308924: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcufft.so.10.0
2019-08-20 13:51:11.527674: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcurand.so.10.0
2019-08-20 13:51:11.664733: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusolver.so.10.0
2019-08-20 13:51:11.763516: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusparse.so.10.0
2019-08-20 13:51:12.068302: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-08-20 13:51:12.068633: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:12.068903: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:12.069008: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1763] Adding visible gpu devices: 0
2019-08-20 13:51:12.069135: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-08-20 13:51:26.728151: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1181] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-08-20 13:51:26.738338: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1187] 0
2019-08-20 13:51:26.738644: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1200] 0: N
2019-08-20 13:51:27.015357: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:27.064916: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:51:27.068805: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1326] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 257 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
>> Downloading speech_commands_v0.02.tar.gz 100.0%
I0820 13:52:25.632115 548396466192 input_data.py:242] Successfully downloaded speech_commands_v0.02.tar.gz (2428923189 bytes)
2019-08-20 13:55:11.506140: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.518426: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1640] Found device 0 with properties:
2019-08-20 13:55:11.522768: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-08-20 13:55:11.538097: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-08-20 13:55:11.538202: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcufft.so.10.0
2019-08-20 13:55:11.538249: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcurand.so.10.0
2019-08-20 13:55:11.538292: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusolver.so.10.0
2019-08-20 13:55:11.538333: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusparse.so.10.0
2019-08-20 13:55:11.578946: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-08-20 13:55:11.579211: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.579463: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.579562: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1763] Adding visible gpu devices: 0
2019-08-20 13:55:11.715736: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.715971: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1640] Found device 0 with properties:
2019-08-20 13:55:11.716065: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-08-20 13:55:11.716174: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-08-20 13:55:11.716240: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcufft.so.10.0
2019-08-20 13:55:11.716293: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcurand.so.10.0
2019-08-20 13:55:11.716348: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusolver.so.10.0
2019-08-20 13:55:11.716405: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusparse.so.10.0
2019-08-20 13:55:11.716464: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-08-20 13:55:11.716709: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.717034: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.717165: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1763] Adding visible gpu devices: 0
2019-08-20 13:55:11.749492: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1181] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-08-20 13:55:11.749567: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1187] 0
2019-08-20 13:55:11.749596: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1200] 0: N
2019-08-20 13:55:11.749967: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.750858: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-08-20 13:55:11.751088: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1326] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 257 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
W0820 13:55:12.965882 548396466192 deprecation.py:506] From /home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py:278: calling dropout (from tensorflow.python.ops.nn_ops) with keep_prob is deprecated and will be removed in a future version.
Instructions for updating:
Please use `rate` instead of `keep_prob`. Rate should be set to `rate = 1 - keep_prob`.
W0820 13:55:13.656599 548396466192 deprecation.py:323] From /usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/losses/losses_impl.py:121: add_dispatch_support.<locals>.wrapper (from tensorflow.python.ops.array_ops) is deprecated and will be removed in a future version.
Use tf.where in 2.0, which has the same broadcast rule as np.where
I0820 13:55:17.648800 548396466192 train.py:195] Training from step: 1
2019-08-20 13:55:20.987891: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-08-20 13:55:22.898557: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-08-20 13:55:30.171781: E tensorflow/stream_executor/cuda/cuda_dnn.cc:319] Loaded runtime CuDNN library: 7.3.1 but source was compiled with: 7.5.0. CuDNN library major and minor version needs to match or have higher minor version in case of CuDNN 7.0 or later version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
2019-08-20 13:55:30.175960: E tensorflow/stream_executor/cuda/cuda_dnn.cc:319] Loaded runtime CuDNN library: 7.3.1 but source was compiled with: 7.5.0. CuDNN library major and minor version needs to match or have higher minor version in case of CuDNN 7.0 or later version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1356, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1341, in _run_fn
options, feed_dict, fetch_list, target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1429, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.UnknownError: 2 root error(s) found.
(0) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above.
[[{{node Conv2D}}]]
[[cross_entropy/sparse_softmax_cross_entropy_loss/value/_31]]
(1) Unknown: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above.
[[{{node Conv2D}}]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File "tensorflow/examples/speech_commands/train.py", line 486, in <module>
tf.compat.v1.app.run(main=main, argv=[sys.argv[0]] + unparsed)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/platform/app.py", line 40, in run
_run(main=main, argv=argv, flags_parser=_parse_flags_tolerate_undef)
File "/usr/local/lib/python3.6/dist-packages/absl/app.py", line 300, in run
_run_main(main, args)
File "/usr/local/lib/python3.6/dist-packages/absl/app.py", line 251, in _run_main
sys.exit(main(argv))
File "tensorflow/examples/speech_commands/train.py", line 234, in main
dropout_prob: 0.5
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 950, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1173, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1350, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py", line 1370, in _do_call
raise type(e)(node_def, op, message)
[[node Conv2D (defined at /home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py:275) ]]
Errors may have originated from an input operation.
Input Source operations connected to node Conv2D:
first_weights/read (defined at /home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py:267)
Reshape (defined at /home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py:260)
Original stack trace for 'Conv2D':
File "tensorflow/examples/speech_commands/train.py", line 139, in main
is_training=True)
File "/home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py", line 133, in create_model
return create_conv_model(fingerprint_input, model_settings, is_training)
File "/home/dlinano/tensorflow-clone/tensorflow/tensorflow/examples/speech_commands/models.py", line 275, in create_conv_model
padding='SAME') + first_bias
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/nn_ops.py", line 1954, in conv2d
name=name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/gen_nn_ops.py", line 1071, in conv2d
data_format=data_format, dilations=dilations, name=name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/op_def_library.py", line 788, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 3616, in create_op
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py", line 2005, in __init__
self._traceback = tf_stack.extract_stack()
