Hello community!
I am currently attempting to implement a CNN model using TensorFlow on Nvidia Jetson Xavier NX (16GB). Previously, the model ran perfectly fine on Windows 10 OS, but it is showing some errors while running on the Nvidia kit. Below are the versions of the libraries and dependencies I have installed:
Jetpack: 5.1-b147
CUDA: 11.8
cuDNN: 8.8.1.3-1 + CUDA 11.8
TensorFlow/Keras: 2.11
Ubuntu: 20.04.6 LTS
GCC: 9.4.0
I have attached screenshots of the errors and the CNN model for reference.
Complete Error:
NotFoundError Traceback (most recent call last)
Cell In[26], line 2
1 # Train the model
----> 2 history=model.fit(x_train, y_train, batch_size=32, epochs=100, validation_data=(x_test, y_test))
File /usr/local/lib/python3.8/dist-packages/keras/utils/traceback_utils.py:70, in filter_traceback..error_handler(*args, **kwargs)
67 filtered_tb = _process_traceback_frames(e.traceback)
68 # To get the full stack trace, call:
69 # tf.debugging.disable_traceback_filtering()
—> 70 raise e.with_traceback(filtered_tb) from None
71 finally:
72 del filtered_tb
File /usr/local/lib/python3.8/dist-packages/tensorflow/python/eager/execute.py:52, in quick_execute(op_name, num_outputs, inputs, attrs, ctx, name)
50 try:
51 ctx.ensure_initialized()
—> 52 tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
53 inputs, attrs, num_outputs)
54 except core._NotOkStatusException as e:
55 if name is not None:
NotFoundError: Graph execution error:
Detected at node ‘sequential/conv2d/Conv2D’ defined at (most recent call last):
File “/usr/lib/python3.8/runpy.py”, line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib/python3.8/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel_launcher.py”, line 17, in
app.launch_new_instance()
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/traitlets/config/application.py”, line 1043, in launch_instance
app.start()
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/kernelapp.py”, line 725, in start
self.io_loop.start()
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/tornado/platform/asyncio.py”, line 215, in start
self.asyncio_loop.run_forever()
File “/usr/lib/python3.8/asyncio/base_events.py”, line 570, in run_forever
self._run_once()
File “/usr/lib/python3.8/asyncio/base_events.py”, line 1859, in _run_once
handle._run()
File “/usr/lib/python3.8/asyncio/events.py”, line 81, in _run
self._context.run(self._callback, *self._args)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/kernelbase.py”, line 513, in dispatch_queue
await self.process_one()
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/kernelbase.py”, line 502, in process_one
await dispatch(*args)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/kernelbase.py”, line 409, in dispatch_shell
await result
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/kernelbase.py”, line 729, in execute_request
reply_content = await reply_content
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/ipkernel.py”, line 422, in do_execute
res = shell.run_cell(
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/ipykernel/zmqshell.py”, line 540, in run_cell
return super().run_cell(*args, **kwargs)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/interactiveshell.py”, line 2961, in run_cell
result = self._run_cell(
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/interactiveshell.py”, line 3016, in _run_cell
result = runner(coro)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/async_helpers.py”, line 129, in pseudo_sync_runner
coro.send(None)
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/interactiveshell.py”, line 3221, in run_cell_async
has_raised = await self.run_ast_nodes(code_ast.body, cell_name,
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/interactiveshell.py”, line 3400, in run_ast_nodes
if await self.run_code(code, result, async=asy):
File “/home/xavier/tensor_env1/lib/python3.8/site-packages/IPython/core/interactiveshell.py”, line 3460, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File “/tmp/ipykernel_16538/3312217822.py”, line 2, in
File “/usr/local/lib/python3.8/dist-packages/keras/utils/traceback_utils.py”, line 65, in error_handler
return fn(*args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 1650, in fit
tmp_logs = self.train_function(iterator)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 1249, in train_function
return step_function(self, iterator)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 1233, in step_function
outputs = model.distribute_strategy.run(run_step, args=(data,))
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 1222, in run_step
outputs = model.train_step(data)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 1023, in train_step
y_pred = self(x, training=True)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 561, in call
return super().call(*args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/base_layer.py”, line 1132, in call
outputs = call_fn(inputs, *args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/keras/utils/traceback_utils.py”, line 96, in error_handler
File “/usr/local/lib/python3.8/dist-packages/keras/engine/sequential.py”, line 413, in call
return super().call(inputs, training=training, mask=mask)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/functional.py”, line 511, in call
return self._run_internal_graph(inputs, training=training, mask=mask)
File “/usr/local/lib/python3.8/dist-packages/keras/engine/functional.py”, line 668, in _run_internal_graph
outputs = node.layer(*args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/keras/layers/convolutional/base_conv.py”, line 283, in call
outputs = self.convolution_op(inputs, self.kernel)
File “/usr/local/lib/python3.8/dist-packages/keras/layers/convolutional/base_conv.py”, line 255, in convolution_op
return tf.nn.convolution(
Node: ‘sequential/conv2d/Conv2D’
No algorithm worked! Error messages:
Profiling failure on CUDNN engine eng1{}: UNKNOWN: CUDNN_STATUS_EXECUTION_FAILED
in tensorflow/compiler/xla/stream_executor/cuda/cuda_dnn.cc(4677): ‘status’
Profiling failure on CUDNN engine eng28{}: UNKNOWN: CUDNN_STATUS_EXECUTION_FAILED
Profiling failure on CUDNN engine eng0{}: UNKNOWN: CUDNN_STATUS_EXECUTION_FAILED
Profiling failure on CUDNN engine eng3{k11=2}: UNKNOWN: CUDNN_STATUS_EXECUTION_FAILED
[[{{node sequential/conv2d/Conv2D}}]] [Op:__inference_train_function_1375]
Thanks and regards!
