I try to use cudaEglStreamProducer to push cuda data over EGL into gstreamer nveglstreamsrc for encoding. I started with example:
- tegra_multimedia_api/argus/samples/gstVideoEncode
However I needed a way to create a producer to push cuda data in so I found this example which helps me a lot:
- /cuda/samples/3_Imaging/EGLStreams_CUDA_Interop
I also found some helpful EGLStream Example provided by DaneLLL here:
I think I got most of the infrastructure running but I didnt got the frames into the producer.
This is how I initialized everything:
CUresult cuResult;
CUdevice cudaDevice;
cuResult = cuInit(0);
cuResult = cuDeviceGet(&cudaDevice, 0);
cuResult = cuCtxCreate(&cu_ctx, 0, cudaDevice);
eglSetupExtensions();
EGLStreamInit();
display = g_display;
streamEGL = eglStream;
cuEGLStreamProducerConnect (&conn, streamEGL, source_width, source_height);
And this is how I want to fill the producer with dummy data:
void* data[3];
cudaMalloc(&data[0],source_width*source_height);
cudaMalloc(&data[1],source_width*source_height/4);
cudaMalloc(&data[2],source_width*source_height/4);
CUeglFrame eglFrame;
eglFrame.width = source_width;
eglFrame.height = source_height;
eglFrame.depth = 1;
eglFrame.pitch = source_width;
eglFrame.planeCount = 3;
eglFrame.numChannels = 1;
eglFrame.frameType = CU_EGL_FRAME_TYPE_PITCH;
eglFrame.eglColorFormat = CU_EGL_COLOR_FORMAT_YUV420_PLANAR;
eglFrame.cuFormat = CU_AD_FORMAT_UNSIGNED_INT8;
eglFrame.frame.pPitch[0] = data[0];
eglFrame.frame.pPitch[1] = data[1];
eglFrame.frame.pPitch[2] = data[2];
CUresult cuStatus = cuEGLStreamProducerPresentFrame(&conn, eglFrame, 0);
if (cuStatus != CUDA_SUCCESS)
std::cout << "cuda Producer present frame FAILED with custatus " << cuStatus << std::endl;
Now this is what I got as result:
eglDisplay Handle created
EGLStream initialized
cuda Producer present frame FAILED with custatus 400
From documentation I can see that error code 400 refers to CUDA_ERROR_INVALID_HANDLE.
So my question is:
- What could this error mean? the only handles that I give to the function are the CUeglConnection and the CUeglFrame. The connection seems to be fine (cuEGLStreamProducerConnect returns 0) so is there some error with my eglFrame?
- Did I forgot something when initializing EGLStreamKHR?
Unfortunately, I could not find anything about cuEGLStreamProducerPresentFrame but the samples I provided above.
