I am trying to do homomorphic filter for a gray scale image. I have pixel information in an int array which will be the input for below:
ln → FFT → filter () → IFFT → exp
For the FFT/IFFT portion i can do the C2C transform vs R2C right?
Provided I prep the data by copying the pixel info into the complex array as below?
Complex *h_signal = (Complex *)malloc(sizeof(Complex) * SIGNAL_SIZE);
for (unsigned int i = 0; i < SIGNAL_SIZE; ++i)
h_signal[i].x = pixel[i];
h_signal[i].y = 0;
Thanks in advance.
