I got this error message when I try to do 1D Complex FFT larger then 2048 pts. The code is the following:
// Test de FFT avec CUDA
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
/ includes, project
#include <cufft.h>
#include <cutil.h>
// Complex data type
typedef float2 Complex;
// declaration, forward
void runTest(int argc, char** argv);
#define ASCII_OUTPUT 0
#define SIGNAL_SIZE 4096
// Program main
int main(int argc, char** argv)
runTest(argc, argv);
CUT_EXIT(argc, argv);
//! Run a simple test for CUDA
int i;
CUT_CHECK_DEVICE();
// Allocate host memory for the signal
Complex* h_signal = (Complex*)malloc(sizeof(Complex) * SIGNAL_SIZE);
// Initalize the memory for the signal
for (unsigned int i = 0; i < SIGNAL_SIZE; ++i) {
h_signal[i].x = rand() / (float)RAND_MAX;
h_signal[i].y = 0;
int mem_size = sizeof(Complex) * SIGNAL_SIZE;
// Allocate device memory for signal
Complex* d_signal;
CUDA_SAFE_CALL(cudaMalloc((void**)&d_signal, mem_size));
// Copy host memory to device
CUDA_SAFE_CALL(cudaMemcpy(d_signal, h_signal, mem_size,
cudaMemcpyHostToDevice));
// CUFFT plan
cufftHandle plan;
CUFFT_SAFE_CALL(cufftPlan1d(&plan, mem_size, CUFFT_DATA_C2C, 1));
// Transform signal and kernel
CUFFT_SAFE_CALL(cufftExecute(plan, d_signal, d_signal, CUFFT_FORWARD));
// Copy device memory to host
Complex* h_result_signal = h_signal;
CUDA_SAFE_CALL(cudaMemcpy(h_result_signal, d_signal, mem_size,
cudaMemcpyDeviceToHost));
// Modif - output
if(ASCII_OUTPUT)
for(i=0; i < SIGNAL_SIZE; i++)
printf("%f\n", h_result_signal[i].y);
// cleanup memory
free(h_signal);
//free(h_result_signal);
//cufftDestroy(plan);
cudaFree(d_signal);
The code work great with FFT < 2048, but I’ve got this error message with 4096 pts FFT:
cufft: ERROR: cufft.cu, line 118
cufft: ERROR: CUFFT_INVALID_PLAN
The CUFTT doc indicate a max fft length of 16384. Does this max length is just for real FFT ?
Thanks !
Edgardz
