and in “res1” I have still error 0x4: CUFFT_INVALID_VALUE.
I tried to run my application on various types of CUDA hardware, on winxp64 and Windows 7x64. I tried to run only mexw64 library with matlab and also winapi in VS2010. I used cufft 3.2 and 4.0 (for x64 system). And I had still the same error. Compiler give no errors (but in VS2010, if I make a new .cu file to changing CUDA settings in Solution properties, I have “error 2” - I’ve readed that the reason of this is that cufft not supports VS2010 correctly).
I checked my mexw library by Dependency Walker and there were no errors. Cufft error 0x4 is still the same, if I’m running my aplicattion on software without CUDA.
oops - this actually brings you back to square one …
could you upload your zipped solution and I’ll try to run it on my machine.
that’ll tell us if it’s something in your code or in the installation on your machine.
