It’s possible. You may be doing something wrong. It’s impossible to say without a complete test case.
This may be of interest:
https://devtalk.nvidia.com/default/topic/863142/problems-when-mix-using-cuda-runtime-api-and-cuda-driver-api/?offset=1
Here’s a fully worked example, a modification of the vectorAddDrv CUDA sample code, that adds a cufft plan operation before a cuModuleLoadDataEx call, and a cufft exec operation after that cuModuleLoadDataEx call, successfully.
vectorAddDrv.cpp:
* Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
/* Vector addition: C = A + B.
* This sample is a very basic sample that implements element by element
* vector addition. It is the same as the sample illustrating Chapter 3
* of the programming guide with some additions like error checking.
// Includes
#include <stdio.h>
#include <string.h>
#include <iostream>
#include <cstring>
// includes, project
#include <helper_functions.h>
#include <helper_cuda.h>
// includes, CUDA
#include <cuda.h>
#include <cudaProfiler.h>
#include <builtin_types.h>
#include <drvapi_error_string.h>
#include <cuda_runtime_api.h>
#include <cufft.h>
using namespace std;
// Variables
CUdevice cuDevice;
CUcontext cuContext;
CUmodule cuModule;
CUfunction vecAdd_kernel;
float *h_A;
float *h_B;
float *h_C;
CUdeviceptr d_A;
CUdeviceptr d_B;
CUdeviceptr d_C;
bool noprompt = false;
// Functions
void Cleanup(bool);
CUresult CleanupNoFailure();
void RandomInit(float *, int);
bool findModulePath(const char *, string &, char **, string &);
void ParseArguments(int, char **);
int *pArgc = NULL;
char **pArgv = NULL;
//define input ptx file for different platforms
#if defined(_WIN64) || defined(__LP64__)
#define PTX_FILE "vectorAdd_kernel64.ptx"
#else
#define PTX_FILE "vectorAdd_kernel32.ptx"
#endif
// These are CUDA Helper functions
// This will output the proper CUDA error strings in the event that a CUDA host call returns an error
#define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__)
// These are the inline versions for all of the SDK helper functions
inline void __checkCudaErrors(CUresult err, const char *file, const int line)
if (CUDA_SUCCESS != err)
fprintf(stderr, "checkCudaErrors() Driver API error = %04d \"%s\" from file <%s>, line %i.\n",
err, getCudaDrvErrorString(err), file, line);
exit(EXIT_FAILURE);
inline int cudaDeviceInit(int ARGC, char **ARGV)
int cuDevice = 0;
int deviceCount = 0;
CUresult err = cuInit(0);
if (CUDA_SUCCESS == err)
checkCudaErrors(cuDeviceGetCount(&deviceCount));
if (deviceCount == 0)
fprintf(stderr, "cudaDeviceInit error: no devices supporting CUDA\n");
exit(EXIT_FAILURE);
int dev = 0;
dev = getCmdLineArgumentInt(ARGC, (const char **) ARGV, "device=");
if (dev < 0)
dev = 0;
if (dev > deviceCount-1)
fprintf(stderr, "\n");
fprintf(stderr, ">> %d CUDA capable GPU device(s) detected. <<\n", deviceCount);
fprintf(stderr, ">> cudaDeviceInit (-device=%d) is not a valid GPU device. <<\n", dev);
return -dev;
checkCudaErrors(cuDeviceGet(&cuDevice, dev));
char name[100];
cuDeviceGetName(name, 100, cuDevice);
if (checkCmdLineFlag(ARGC, (const char **) ARGV, "quiet") == false)
printf("> Using CUDA Device [%d]: %s\n", dev, name);
return dev;
// This function returns the best GPU based on performance
inline int getMaxGflopsDeviceId()
CUdevice current_device = 0, max_perf_device = 0;
int device_count = 0, sm_per_multiproc = 0;
int max_compute_perf = 0, best_SM_arch = 0;
int major = 0, minor = 0, multiProcessorCount, clockRate;
cuInit(0);
checkCudaErrors(cuDeviceGetCount(&device_count));
// Find the best major SM Architecture GPU device
while (current_device < device_count)
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device));
if (major > 0 && major < 9999)
best_SM_arch = MAX(best_SM_arch, major);
current_device++;
// Find the best CUDA capable GPU device
current_device = 0;
checkCudaErrors(cuDeviceGetAttribute(&multiProcessorCount,
CU_DEVICE_ATTRIBUTE_MULTIPROCESSOR_COUNT,
current_device));
checkCudaErrors(cuDeviceGetAttribute(&clockRate,
CU_DEVICE_ATTRIBUTE_CLOCK_RATE,
current_device));
if (major == 9999 && minor == 9999)
sm_per_multiproc = 1;
else
sm_per_multiproc = _ConvertSMVer2Cores(major, minor);
int compute_perf = multiProcessorCount * sm_per_multiproc * clockRate;
if (compute_perf > max_compute_perf)
// If we find GPU with SM major > 2, search only these
if (best_SM_arch > 2)
// If our device==dest_SM_arch, choose this, or else pass
if (major == best_SM_arch)
max_compute_perf = compute_perf;
max_perf_device = current_device;
else
++current_device;
return max_perf_device;
// General initialization call to pick the best CUDA Device
inline CUdevice findCudaDevice(int argc, char **argv, int *p_devID)
CUdevice cuDevice;
int devID = 0;
// If the command-line has a device number specified, use it
if (checkCmdLineFlag(argc, (const char **)argv, "device"))
devID = cudaDeviceInit(argc, argv);
if (devID < 0)
printf("exiting...\n");
exit(EXIT_SUCCESS);
else
// Otherwise pick the device with highest Gflops/s
char name[100];
devID = getMaxGflopsDeviceId();
checkCudaErrors(cuDeviceGet(&cuDevice, devID));
printf("> Using CUDA Device [%d]: %s\n", devID, name);
cuDeviceGet(&cuDevice, devID);
if (p_devID)
*p_devID = devID;
return cuDevice;
// end of CUDA Helper Functions
// Host code
int main(int argc, char **argv)
pArgc = &argc;
pArgv = argv;
printf("Vector Addition (Driver API)\n");
int N = 50000, devID = 0;
size_t size = N * sizeof(float);
CUresult error;
ParseArguments(argc, argv);
// Initialize
checkCudaErrors(cuInit(0));
// This assumes that the user is attempting to specify a explicit device -device=n
if (argc > 1)
bool bFound = false;
for (int param=0; param < argc; param++)
int string_start = 0;
while (argv[param][string_start] == '-')
string_start++;
char *string_argv = &argv[param][string_start];
if (!strncmp(string_argv, "device", 6))
int len=(int)strlen(string_argv);
while (string_argv[len] != '=')
len--;
devID = atoi(&string_argv[++len]);
bFound = true;
if (bFound)
break;
// Get number of devices supporting CUDA
error = cuDeviceGetCount(&deviceCount);
if (error != CUDA_SUCCESS)
Cleanup(false);
printf("There is no device supporting CUDA.\n");
Cleanup(false);
if (devID < 0)
devID = 0;
if (devID > deviceCount-1)
fprintf(stderr, "(Device=%d) invalid GPU device. %d GPU device(s) detected.\nexiting...\n", devID, deviceCount);
CleanupNoFailure();
exit(EXIT_SUCCESS);
else
int major, minor;
char deviceName[100];
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, devID));
checkCudaErrors(cuDeviceGetName(deviceName, 256, devID));
printf("> Using Device %d: \"%s\" with Compute %d.%d capability\n", devID, deviceName, major, minor);
// pick up device with zero ordinal (default, or devID)
error = cuDeviceGet(&cuDevice, devID);
Cleanup(false);
// Create context
error = cuCtxCreate(&cuContext, 0, cuDevice);
Cleanup(false);
// CUFFT add
cudaSetDevice(devID); // should cause CUDA runtime to use the same context
cufftComplex *cdata;
cudaMalloc((void **)&cdata, 1024*sizeof(cufftComplex));
cufftHandle plan;
cufftResult cstat = cufftPlan1d(&plan, 1024, CUFFT_C2C, 1);
if (cstat != CUFFT_SUCCESS) printf("CUFFT1 cstat = %d\n", (int)cstat);
printf("call to cufftPlan1d complete \n");
// first search for the module path before we load the results
string module_path, ptx_source;
if (!findModulePath(PTX_FILE, module_path, argv, ptx_source))
if (!findModulePath("vectorAdd_kernel.cubin", module_path, argv, ptx_source))
printf("> findModulePath could not find <vectorAdd> ptx or cubin\n");
Cleanup(false);
else
printf("> initCUDA loading module: <%s>\n", module_path.c_str());
// Create module from binary file (PTX or CUBIN)
if (module_path.rfind("ptx") != string::npos)
// in this branch we use compilation with parameters
const unsigned int jitNumOptions = 3;
CUjit_option *jitOptions = new CUjit_option[jitNumOptions];
void **jitOptVals = new void *[jitNumOptions];
// set up size of compilation log buffer
jitOptions[0] = CU_JIT_INFO_LOG_BUFFER_SIZE_BYTES;
int jitLogBufferSize = 1024;
jitOptVals[0] = (void *)(size_t)jitLogBufferSize;
// set up pointer to the compilation log buffer
jitOptions[1] = CU_JIT_INFO_LOG_BUFFER;
char *jitLogBuffer = new char[jitLogBufferSize];
jitOptVals[1] = jitLogBuffer;
// set up pointer to set the Maximum # of registers for a particular kernel
jitOptions[2] = CU_JIT_MAX_REGISTERS;
int jitRegCount = 32;
jitOptVals[2] = (void *)(size_t)jitRegCount;
error = cuModuleLoadDataEx(&cuModule, ptx_source.c_str(), jitNumOptions, jitOptions, (void **)jitOptVals);
printf("call to cuModuleLoadDataEx complete \n");
printf("> PTX JIT log:\n%s\n", jitLogBuffer);
else
error = cuModuleLoad(&cuModule, module_path.c_str());
Cleanup(false);
// Get function handle from module
error = cuModuleGetFunction(&vecAdd_kernel, cuModule, "VecAdd_kernel");
Cleanup(false);
// CUFFT Add
cstat = cufftExecC2C(plan, cdata, cdata, CUFFT_FORWARD);
if (cstat != CUFFT_SUCCESS) printf("CUFFT2 cstat = %d\n", (int)cstat);
printf("call to cufftExecC2C complete \n");
// Allocate input vectors h_A and h_B in host memory
h_A = (float *)malloc(size);
if (h_A == 0)
Cleanup(false);
h_B = (float *)malloc(size);
if (h_B == 0)
Cleanup(false);
h_C = (float *)malloc(size);
if (h_C == 0)
Cleanup(false);
// Initialize input vectors
RandomInit(h_A, N);
RandomInit(h_B, N);
// Allocate vectors in device memory
error = cuMemAlloc(&d_A, size);
Cleanup(false);
error = cuMemAlloc(&d_B, size);
Cleanup(false);
error = cuMemAlloc(&d_C, size);
Cleanup(false);
// Copy vectors from host memory to device memory
error = cuMemcpyHtoD(d_A, h_A, size);
Cleanup(false);
error = cuMemcpyHtoD(d_B, h_B, size);
Cleanup(false);
#if 1
if (1)
// This is the new CUDA 4.0 API for Kernel Parameter Passing and Kernel Launch (simpler method)
// Grid/Block configuration
int threadsPerBlock = 256;
int blocksPerGrid = (N + threadsPerBlock - 1) / threadsPerBlock;
void *args[] = { &d_A, &d_B, &d_C, &N };
// Launch the CUDA kernel
error = cuLaunchKernel(vecAdd_kernel, blocksPerGrid, 1, 1,
threadsPerBlock, 1, 1,
0,
NULL, args, NULL);
Cleanup(false);
else
// This is the new CUDA 4.0 API for Kernel Parameter Passing and Kernel Launch (advanced method)
int offset = 0;
void *argBuffer[16];
*((CUdeviceptr *)&argBuffer[offset]) = d_A;
offset += sizeof(d_A);
*((CUdeviceptr *)&argBuffer[offset]) = d_B;
offset += sizeof(d_B);
*((CUdeviceptr *)&argBuffer[offset]) = d_C;
offset += sizeof(d_C);
*((int *)&argBuffer[offset]) = N;
offset += sizeof(N);
0,
NULL, NULL, argBuffer);
Cleanup(false);
#else
char argBuffer[256];
// pass in launch parameters (not actually de-referencing CUdeviceptr). CUdeviceptr is
// storing the value of the parameters
void *kernel_launch_config[5] =
CU_LAUNCH_PARAM_BUFFER_POINTER, argBuffer,
CU_LAUNCH_PARAM_BUFFER_SIZE, &offset,
CU_LAUNCH_PARAM_END
0, 0,
NULL, (void **)&kernel_launch_config);
Cleanup(false);
#endif
#ifdef _DEBUG
error = cuCtxSynchronize();
Cleanup(false);
#endif
// Copy result from device memory to host memory
// h_C contains the result in host memory
error = cuMemcpyDtoH(h_C, d_C, size);
Cleanup(false);
// Verify result
int i;
for (i = 0; i < N; ++i)
float sum = h_A[i] + h_B[i];
if (fabs(h_C[i] - sum) > 1e-7f)
break;
printf("%s\n", (i==N) ? "Result = PASS" : "Result = FAIL");
cuProfilerStop();
exit((i==N) ? EXIT_SUCCESS : EXIT_FAILURE);
CUresult error;
// Free device memory
if (d_A)
error = cuMemFree(d_A);
if (d_B)
error = cuMemFree(d_B);
if (d_C)
error = cuMemFree(d_C);
// Free host memory
if (h_A)
free(h_A);
if (h_B)
free(h_B);
if (h_C)
free(h_C);
error = cuCtxDestroy(cuContext);
return error;
void Cleanup(bool noError)
CUresult error;
error = CleanupNoFailure();
if (!noError || error != CUDA_SUCCESS)
printf("Function call failed\nFAILED\n");
exit(EXIT_FAILURE);
if (!noprompt)
printf("\nPress ENTER to exit...\n");
fflush(stdout);
fflush(stderr);
getchar();
// Allocates an array with random float entries.
void RandomInit(float *data, int n)
for (int i = 0; i < n; ++i)
data[i] = rand() / (float)RAND_MAX;
bool inline
findModulePath(const char *module_file, string &module_path, char **argv, string &ptx_source)
char *actual_path = sdkFindFilePath(module_file, argv[0]);
if (actual_path)
module_path = actual_path;
else
printf("> findModulePath file not found: <%s> \n", module_file);
return false;
if (module_path.empty())
printf("> findModulePath could not find file: <%s> \n", module_file);
return false;
else
printf("> findModulePath found file at <%s>\n", module_path.c_str());
if (module_path.rfind(".ptx") != string::npos)
FILE *fp = fopen(module_path.c_str(), "rb");
fseek(fp, 0, SEEK_END);
int file_size = ftell(fp);
char *buf = new char[file_size+1];
fseek(fp, 0, SEEK_SET);
fread(buf, sizeof(char), file_size, fp);
fclose(fp);
buf[file_size] = '
- Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
- Please refer to the NVIDIA end user license agreement (EULA) associated
- with this source code for terms and conditions that govern your use of
- this software. Any use, reproduction, disclosure, or distribution of
- this software and related documentation outside the terms of the EULA
- is strictly prohibited.
- This sample is a very basic sample that implements element by element
- vector addition. It is the same as the sample illustrating Chapter 3
- of the programming guide with some additions like error checking.
// Includes
#include <stdio.h>
#include <string.h>
#include
#include
// includes, CUDA
#include <cuda.h>
#include <cufft.h>
// Variables
CUdevice cuDevice;
CUmodule cuModule;
float *h_A;
float *h_B;
float *h_C;
CUdeviceptr d_A;
CUdeviceptr d_B;
CUdeviceptr d_C;
// Functions
void Cleanup(bool);
int *pArgc = NULL;
#if defined(_WIN64) || defined(LP64)
#define PTX_FILE “vectorAdd_kernel64.ptx”
#else
#define PTX_FILE “vectorAdd_kernel32.ptx”
#endif
#define checkCudaErrors(err) __checkCudaErrors (err, FILE, LINE)
fprintf(stderr, “checkCudaErrors() Driver API error = %04d “%s” from file <%s>, line %i.\n”,
exit(EXIT_FAILURE);
int cuDevice = 0;
exit(EXIT_FAILURE);
int dev = 0;
if (dev < 0)
dev = 0;
return -dev;
char name[100];
return dev;
cuInit(0);
current_device++;
current_device = 0;
current_device));
current_device));
else
else
++current_device;
CUdevice cuDevice;
int devID = 0;
if (devID < 0)
exit(EXIT_SUCCESS);
else
char name[100];
if (p_devID)
*p_devID = devID;
return cuDevice;
// Host code
pArgc = &argc;
pArgv = argv;
CUresult error;
// Initialize
if (argc > 1)
string_start++;
len--;
bFound = true;
if (bFound)
break;
Cleanup(false);
Cleanup(false);
if (devID < 0)
devID = 0;
CleanupNoFailure();
exit(EXIT_SUCCESS);
else
int major, minor;
Cleanup(false);
// Create context
Cleanup(false);
// CUFFT add
cufftComplex cdata;
cudaMalloc((void **)&cdata, 1024sizeof(cufftComplex));
cufftHandle plan;
if (cstat != CUFFT_SUCCESS) printf(“CUFFT1 cstat = %d\n”, (int)cstat);
printf(“call to cufftPlan1d complete \n”);
Cleanup(false);
else
else
Cleanup(false);
Cleanup(false);
// CUFFT Add
if (cstat != CUFFT_SUCCESS) printf(“CUFFT2 cstat = %d\n”, (int)cstat);
printf(“call to cufftExecC2C complete \n”);
if (h_A == 0)
Cleanup(false);
if (h_B == 0)
Cleanup(false);
if (h_C == 0)
Cleanup(false);
RandomInit(h_A, N);
RandomInit(h_B, N);
Cleanup(false);
Cleanup(false);
Cleanup(false);
Cleanup(false);
Cleanup(false);
#if 1
if (1)
0,
NULL, args, NULL);
Cleanup(false);
else
int offset = 0;
0,
Cleanup(false);
#else
CU_LAUNCH_PARAM_END
0, 0,
Cleanup(false);
#endif
#ifdef _DEBUG
Cleanup(false);
#endif
Cleanup(false);
// Verify result
int i;
break;
cuProfilerStop();
CUresult error;
if (d_A)
if (d_B)
if (d_C)
// Free host memory
if (h_A)
free(h_A);
if (h_B)
free(h_B);
if (h_C)
free(h_C);
return error;
CUresult error;
exit(EXIT_FAILURE);
if (!noprompt)
fflush(stdout);
fflush(stderr);
getchar();
bool inline
if (actual_path)
else
return false;
return false;
else
fclose(fp);
buf[file_size] = '\0';
ptx_source = buf;
delete[] buf;
return true;
// Parse program arguments
void ParseArguments(int argc, char **argv)
for (int i = 0; i < argc; ++i)
if (strcmp(argv[i], “–noprompt”) == 0 ||
strcmp(argv[i], “-noprompt”) == 0)
noprompt = true;
break;
ptx_source = buf;
delete[] buf;
return true;
if (strcmp(argv[i], "--noprompt") == 0 ||
strcmp(argv[i], "-noprompt") == 0)
noprompt = true;
break;
(no change to the ptx kernel)
compile/run:
$ nvcc -ptx vectorAdd_kernel.cu -o vectorAdd_kernel64.ptx
$ nvcc -I/usr/local/cuda/samples/common/inc -o vectorAddDrv vectorAddDrv.cpp -lcufft -lcuda
$ cuda-memcheck ./vectorAddDrv
========= CUDA-MEMCHECK
> Using Device 0: "Quadro 5000" with Compute 2.0 capability
> findModulePath found file at <./vectorAdd_kernel64.ptx>
> initCUDA loading module: <./vectorAdd_kernel64.ptx>
> PTX JIT log:
Result = PASS
========= ERROR SUMMARY: 0 errors
