CUFFT performance not good How to correctly find the excution time on CPU and GPU
Hello
I wrote the following code utilizing CUFFT Library for calculating FFT of 256 numbers and in 10 Batches. I have following questions in this regard:
1- Am I using the correct way for calculating the elapsed time for cufftExecC2C ( Basically I am using CUDA Event) ?
2- To calculate the execution time on the CPU, I am simple running the program in emulation mode -deviceemu. Based on the method of calculating the execution time I am using, I am observing that there is no benefit in performing the FFT on the GPU. I checked my results by varying the number of batches from 10 to 6000, and the benefit that I am observing is almost negligible; Am I doing something wrong while calculating the timing?
Thanks in advance.
#include <stdio.h>
#include <math.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <cufft.h>
#include <cuda.h>
#define NX	  256
#define BATCH   10
int main()
		cufftHandle plan;
		cufftComplex *devPtr;
		cufftComplex data[NX*BATCH];
		int i;
																																																													/* source data creation */
		for(i=  0; i < NX*BATCH; i++){
				data[i].x = 1.0f;
				data[i].y = 1.0f;
cudaEvent_t start,stop;
float time;
cudaEventCreate(&start);
cudaEventCreate(&stop);
	/* GPU memory allocation */
		cudaMalloc((void**)&devPtr, sizeof(cufftComplex)*NX*BATCH);
	/* transfer to GPU memory */
		cudaMemcpy(devPtr, data, sizeof(cufftComplex)*NX*BATCH, cudaMemcpyHostToDevice);
		/* creates 1D FFT plan */
		cufftPlan1d(&plan, NX, CUFFT_C2C, BATCH);
/* Timing Calculations*/
cudaEventRecord( start, 0 );
		/* executes FFT processes */
		cufftExecC2C(plan, devPtr, devPtr, CUFFT_FORWARD);
cudaThreadSynchronize();
cudaEventRecord( stop , 0 );
cudaEventSynchronize( stop );
float elapsedTime;
cudaEventElapsedTime( &elapsedTime, start, stop );
printf("Processing time=%f(ms)\n",elapsedTime);
cudaEventDestroy( start );
cudaEventDestroy( stop );
		   /* transfer results from GPU memory */
		cudaMemcpy(data, devPtr, sizeof(cufftComplex)*NX*BATCH, cudaMemcpyDeviceToHost);
		/* deletes CUFFT plan */
		cufftDestroy(plan);
	/* frees GPU memory */
		cudaFree(devPtr);
		/*for(i = 0; i < NX*BATCH; i++){
				printf("data[%d] %f %f\n", i, data[i].x, data[i].y);
		return 0;
10x 256 point FFTs is a very small amount of data. I think in order to get impressive performance, you will need to increase your test size two or three orders of magnitude. That will require you to get the data off the stack and onto the heap. Oh and you may want to use pinned memory.
