cuModuleLoadData returned error 300
Hello!
I installed the current CUDA toolkit and verify the installation by the SDK samples (eigenvalues, MonteCarlo).
pgcc -o c1.exe c1.c -ta=nvidia -Minfo=accel -fast
compilied without any error, but when I run the programm I obtain the error
call to cuModuleLoadData returned error 300: Invalid source
What’s the problem?
Thanks a lot!
With kind regards
Mathias
My System
Ubuntu 9.10
Intel Core 2 Duo E6750
GeForce 9800 GTX
NVIDIA Driver Version 180.44
NV-Control Version 1.17
I established the file sitevrc with the entry GCCVERSION=40301[/code]
Can you please send code to trs@pgroup.com so we can investigate?
Thank you,
Hongyon
Hi Mathias,
Try compilng with “-ta=nvidia,cc11”. This error typically occurs when there is a mismatch in the compute capabitity version. By default, the compiler targets CC 1.3. “cc11” tells the compiler to target CC 1.1.
Also, “GCCVERSION=40301” should only be used if you have GCC 4.3 installed.
  • Mat
