Curand Problem (newbie)
Hi, I’m a newbie on CUDA and is my first time in this site.
I have a 9800gtx+ with capability 1.1 and I tried to compile the example in Curand_Library.pdf with Host_api and I had this problem
/tmp/tmpxft_00005941_00000000-13_curand_host.o: In function `main':
tmpxft_00005941_00000000-1_curand_host.cudafe1.cpp:(.text+0x7f): undefined reference to `curandCreateGenerator'
tmpxft_00005941_00000000-1_curand_host.cudafe1.cpp:(.text+0xca): undefined reference to `curandSetPseudoRandomGeneratorSeed'
tmpxft_00005941_00000000-1_curand_host.cudafe1.cpp:(.text+0x115): undefined reference to `curandGenerateUniform'
tmpxft_00005941_00000000-1_curand_host.cudafe1.cpp:(.text+0x1e5): undefined reference to `curandDestroyGenerator'
collect2: ld returned 1 exit status
Do you what is this problem?
Sorry for my english
It seems like a linking problem.
Could you write the compilation command that you are trying to execute?
nvcc -o run curand_host.cu
but this program run with out problem My first CUDA program! | /// Parallel Panorama ///
You need to add the name of the library you want to link and where it is located on your system.
nvcc -o run curand_host.cu -L/usr/local/cuda/lib64 -lcurand
Thank you very much, do you know what to do with atomic functions, which is the right library?
I compile without -L/usr/local/cuda/lib64 because I have the LD_LIBRARY_PATH environment variable
