Custom deepstream ssd parser python app
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.0
• TensorRT Version 8.0
• NVIDIA GPU Driver Version (valid for GPU only) 11.4
im using onnx model loaded through triton server ,
i get the metadata , but im not getting the bouding box . Could you please help
in the parser.py below output layers are added output, 573, 625, 677 ,
def nvds_infer_parse_custom_tf_ssd(output_layer_info, detection_param, box_size_param,                                   nms_param=NmsParam()):
    """ Get data from output_layer_info and fill object_list
        with several NvDsInferObjectDetectionInfo.
        Keyword arguments:
        - output_layer_info : represents the neural network's output.
            (NvDsInferLayerInfo list)
        - detection_param : contains per class threshold.
            (DetectionParam)
        - box_size_param : element containing information to discard boxes
            that are too small. (BoxSizeParam)
        - nms_param : contains information for performing non maximal
            suppression. (NmsParam)
        Return:
        - Bounding boxes. (NvDsInferObjectDetectionInfo list)
    num_detection_layer = layer_finder(output_layer_info, "output")
    score_layer = layer_finder(output_layer_info, "573")
    class_layer = layer_finder(output_layer_info, "625")
    box_layer = layer_finder(output_layer_info, "677")
HI @h9945394143
You need to add parser code to parse the output data and generate the BBOXes
its yolov5 model , i have generated so file from nvdsparserbox_yolo.cpp (attached file)
libnvdsinfer_custom_impl_Yolo.so is generated so file used .
below is my config file
  preprocess {
    network_format: IMAGE_FORMAT_RGB
    tensor_order: TENSOR_ORDER_LINEAR
    maintain_aspect_ratio: 0
    frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
    frame_scaling_filter: 1
    normalize {
      scale_factor: 0.0078125
      channel_offsets: [128, 128, 128]
  postprocess {
    labelfile_path: "labels.txt"
        detection {
      num_detected_classes: 1
      custom_parse_bbox_func:"NvDsInferParseCustomYoloV5"
      nms {
        confidence_threshold: 0.25
        iou_threshold: 0.3
        topk : 20
  extra {
    copy_input_to_host_buffers: false
    output_buffer_pool_size: 2
  custom_lib {
    path:"libnvdsinfer_custom_impl_Yolo.so"
input_control {
  process_mode: PROCESS_MODE_FULL_FRAME
  interval: 0
output_control {
  output_tensor_meta: true
nvdsparsebbox_Yolo.cpp (5.5 KB)
Hi @h9945394143
Did Yolov5 giving wrong output - #15 by mchi help you out?
its been fixed . please close it .
