Deepstream ssd parser python example coordinate and output
• DeepStream Version
DS 6.1.1 nvcr.io/nvidia/deepstream:6.1.1-triton
questions
Hi All,
I am following deepstream python ssd example to understand deploying a custom model with triton inference server and parsing the result with python.
Ref: deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
From SSD bounding box format, the output for the box.layer buffer should follow
[x1, y1, x2, y2]
where (x1, y1) is te top left corner, and (x2, y2) is the bottom right corner. Is this correct?
But when I follow the code Inside ssd_parser.py, I am confused with the x-y coordinate settings.
rect_x1_f = clip_1d_elm(0)
rect_y1_f = clip_1d_elm(1)
rect_x2_f = clip_1d_elm(2)
rect_y2_f = clip_1d_elm(3)
res.left = rect_y1_f
res.top = rect_x1_f
res.width = rect_y2_f - rect_y1_f
res.height = rect_x2_f - rect_x1_f
where res is NvDsInferObjectDetectionInfo()
https://docs.nvidia.com/metropolis/deepstream/python-api/PYTHON_API/NvDsInfer/NvDsInferObjectDetectionInfo.html
for property res.left and res.top, I wonder why the horizontal offset uses the y-axis output from the model? and vice versa for vertical offset.
Please kindly advise.
• TensorRT Version
RTX 3090
• TensorRT Version
515.86.01
questions
sample application deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
sorry for the late reply, yes, you are right, please refer to NvDsInferParseCustomTfSSD in deepstream SDK.
Currently, I found the logics of python code is different with C code, please refer to NvDsInferParseCustomTfSSD in deepstream SDK, opt\nvidia\deepstream\deepstream\sources\libs\nvdsinfer_customparser\nvdsinfer_custombboxparser.cpp.
will continue to check.
the code result is right, but the variable names are not right.
here is the original code:
res.top = rect_x1_f
here is the right code:
rect_y1_f = clip_1d_elm(0) #y1
rect_x1_f = clip_1d_elm(1) #x1
rect_y2_f = clip_1d_elm(2) #y2
rect_x2_f = clip_1d_elm(3) #x2
res.left = rect_x1_f
res.top = rect_y1_f
res.width = rect_x2_f - rect_x1_f
res.height = rect_y2_f - rect_y1_f
The clip_1d_elm function use pyds.get_detections(box_layer.buffer, index * 4 + index2) to get the result from the box_layer buffer. So does it mean the SSD bounding box format follows [y1, x1, y2, x2]?
from the corresponding parsing code(C/python), the model’s output format is [y1, x1, y2, x2].
here is the c code, the logic is clear.
enum {y1, x1, y2, x2};
float rectX1f, rectY1f, rectX2f, rectY2f;
rectX1f = ((float*)boxLayer->buffer)[i *4 + 1] * networkInfo.width;
rectY1f = ((float*)boxLayer->buffer)[i *4 + 0] * networkInfo.height;
rectX2f = ((float*)boxLayer->buffer)[i *4 + 3] * networkInfo.width;;
rectY2f = ((float*)boxLayer->buffer)[i *4 + 2] * networkInfo.height;
