• Hardware Platform:
GPU NVIDIA L40S
• DeepStream Version:
7.1
• TensorRT Version:
Aligned with DeepStream 7.1 recommendations
• Issue Type:
Questions
• Requirement Details:
Hi everyone,
I have deployed a DeepStream application using Kubernetes and integrated the Kafka message broker plugin (nvmsgconv and nvmsgbroker). Now, I would like to send a custom payload that includes information such as tracking ID, bounding box (bbox), region of interest (ROI), and detected object details.
How can I achieve this?
Here is my current configuration file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=60
[source0]
enable=1
type=4
uri=<my_rtsp>
num-sources=1
gpu-id=0
latency=200
drop-frame-interval=2
rtsp-reconnect-interval-sec=30
select-rtp-protocol=4
camera-fps-n=12
camera-fps-d=1
[primary-gie]
enable=1
batch-size=1
gie-unique-id=1
labelfile-path=labels.txt
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[sink0]
enable=1
gpu-id=0
type=4
sync=0
codec=1
nvbuf-memory-type=0
bitrate=4000000
iframeinterval=10
rtsp-port=8554
udp-port=5555
profile=0
udp-buffer-size=1000000
qos=0
[sink1]
type=6
enable=1
msg-conv-payload-type=0
msg-conv-msg2p-new-api=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
msg-broker-conn-str=<my_IP>;9092;ds-avio-test
topic=ds-avio-test
nvbuf-memory-type=0
msg-conv-msg2p-lib=/opt/nvidia/deepstream/deepstream-7.1/lib/libnvds_msgconv.so
msg-conv-comp-id=1
msg-broker-comp-id=1
msg-conv-config=msgconv_config.txt
sync=0
[streammux]
gpu-id=0
live-source=1
batch-size=1
batched-push-timeout=4000
width=1920
height=1080
enable-padding=1
nvbuf-memory-type=0
attach-sys-ts-as-ntp=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=10
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[tiled-display]
enable=1
rows=1
columns=1
width=1920
height=1080
gpu-id=0
[tracker]
enable=1
tracker-width=320
tracker-height=320
ll-lib-file=../libs/libnvds_nvmultiobjecttracker.so
ll-config-file=config_tracker_NvDCF_accuracy.yml
gpu-id=0
display-tracking-id=1
Any guidance on how to modify msgconv_config.txt or other settings to include custom metadata would be greatly appreciated.
Thanks in advance!
