What advantages I do get using msgconv or msgcbroker over KafkaProducer (pip package kafka-python)?
Hi I am trying to run deepstream test 4 python sample app and was able to run it successfully but I want to send a custom payload instead of the default one and I am confused on how to send those.
To tackle the issue temporary, I came across this pip package kafka-python where we can send data to kafka by using KafkaProducer method like this
producer = KafkaProducer(
bootstrap_servers='<IP>:9092',
value_serializer=lambda x: dumps(x).encode('utf-8')
producer.send('test', value=test_dict)
So what benefits do msgbroker offers over Kafka pip package? And what is the right approach? If right approach is to use msgbroker then how to send a custom payload (I tried creating a custom payload but failed with “terminate called after throwing an instance of ‘std::bad_function_call’” )?
PS I ran KafkaProducer with 10 simultaneous streams and it doesn’t affect the FPS.
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.01
• TensorRT Version
Hey, we will check it internally and update ASAP.
@bcao any Update?
+1 @bcao
Sorry for the late, it should be fine to use the KafkaProducer Python package . Using the msgconv+msgbroker plugins allows tee/queue elements in the pipeline to parallelize the Kafka message sending with visual output. When sending message directly from a probe function, the message sending blocks the downstream pipeline until it’s done.
Thanks for the reply. I m trying to send a custom JSON object from deepstream using Kafka but there is no information/documentation on NvDsPayloadObject.
Can you please guide me through it?
REFER: How to build a custom object to use on payloads for message broker with Python Bindings - #3 by bcao
Sorry for the delay, yeah, we will check and update it in that topic.
