Can’t compile deepstream nvmsgconv file on Jetson.
root@ubuntu:/opt/nvidia/deepstream/deepstream-6.2/sources/libs/nvmsgconv# make install
protoc -I./deepstream_schema --cpp_out=./deepstream_schema/ Makefile
Makefile: File does not reside within any path specified using --proto_path (or -I). You must specify a --proto_path which encompasses this file. Note that the proto_path must be an exact prefix of the .proto file names – protoc is too dumb to figure out when two paths (e.g. absolute and relative) are equivalent (it’s harder than you think).
make: *** [Makefile:53: deepstream_schema/schema.pb.cc] Error 1
• Hardware Platform (Jetson / GPU) : Jetson ORIN AGX 32GB DEV KIT • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) 5.1.1
Is there a tutorial or example to use custom binding objects to be embedded in custom payload using kafka?
Thanks @junshengy I added schema.proto. I am able to send custom objects.
My kakfka library is breaking when I am sending huge string for a field (frame image bytes to base64 strings). Is there an upper limit for STRING_PROPERTY size?
I increased Kafka message size. It is around 5MB, but it still fails with the error:
Error :
Error: gst-library-error-quark: GStreamer encountered a general supporting library error. (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.cpp(522): legacy_gst_nvmsgbroker_render (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
I am running python bindings code on a custom app similar to deepstream-test4 but instead of sending custom vehicle and person object, I am sending custom objects. I can successfully send messages to kafka server as long the size of messages is small. Is there any limitation on deepstream side for string properties for custom objects.
I solved the problem here.
Update kafka server, topic and consumer for large messages.
Deepstream App changes:
proto-cfg = “message.max.bytes=10485880” had to be added in cfg_kafka.txt
and had to explicitly free the pointer for the field with huge string.
and had to make sure buffer is freed even if it is part of extMsg. Since it is a huge string. free of extMsg doesn’t get free and cause
