AK51
August 30, 2022, 6:41am
1
I use “labelme” for the annotation, I wonder if I can do the training in Orin? If not, is there any tutorial of segmentation training and use dusty-nv for inference?
Thx
Yes, you can apply training on Orin.
Please check if the below document can meet your requirements.
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="depthnet.md">Back</a> | <a href="pytorch-cat-dog.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning</sup></s></p>
# Transfer Learning with PyTorch
Transfer learning is a technique for re-training a DNN model on a new dataset, which takes less time than training a network from scratch. With transfer learning, the weights of a pre-trained model are fine-tuned to classify a customized dataset. In these examples, we'll be using the <a href="https://arxiv.org/abs/1512.03385">ResNet-18</a> and [SSD-Mobilenet](pytorch-ssd.md) networks, although you can experiment with other networks too.
<p align="center"><a href="https://arxiv.org/abs/1512.03385"><img src="https://github.com/dusty-nv/jetson-inference/raw/python/docs/images/pytorch-resnet-18.png" width="600"></a></p>
Although training is typically performed on a PC, server, or cloud instance with discrete GPU(s) due to the often large datasets used and the associated computational demands, by using transfer learning we're able to re-train various networks onboard Jetson to get started with training and deploying our own DNN models.
<a href=https://pytorch.org/>PyTorch</a> is the machine learning framework that we'll be using, and example datasets along with training scripts are provided to use below, in addition to a camera-based tool for collecting and labeling your own training datasets.
## Installing PyTorch
If you are [Running the Docker Container](aux-docker.md) or optionally chose to install PyTorch back when you [Built the Project](building-repo-2.md#installing-pytorch), it should already be installed on your Jetson to use. Otherwise, if you aren't using the container and want to proceed with transfer learning, you can install it now:
``` bash
This file has been truncated. show original
AK51
August 30, 2022, 8:57am
4
I don’t see segmentation train in dusty-nv github.
Only classification and object detection.
Please correct me if I am wrong.
Or, you mean I can use the object detection training for segmentation??
Thx
Hi @AK51 , there is a previous tutorial for semantic segmentation training here:
AK51
August 31, 2022, 5:19am
7
Yes, it works.
Thanks Dusty. :>
system
Closed
September 21, 2022, 4:56am
9
