Hello all,
Recently, i wrote my own code to use cusparse module while interfacing with C library.
The code was compiled well but executed in a wrong way.
Can you take a look at my code for what is wrong?
Much appreciate it.
Kevin
module cusparse_m
use iso_c_binding
enum, bind(C) ! cusparseStatus_t
enumerator :: CUSPARSE_STATUS_SUCCESS=0
enumerator :: CUSPARSE_STATUS_NOT_INITIALIZED=1
enumerator :: CUSPARSE_STATUS_ALLOC_FAILED=2
enumerator :: CUSPARSE_STATUS_INVALID_VALUE=3
enumerator :: CUSPARSE_STATUS_ARCH_MISMATCH=4
enumerator :: CUSPARSE_STATUS_MAPPING_ERROR=5
enumerator :: CUSPARSE_STATUS_EXECUTION_FAILED=6
enumerator :: CUSPARSE_STATUS_INTERNAL_ERROR=7
enumerator :: CUSPARSE_STATUS_MATRIX_TYPE_NOT_SUPPORTED=8
end enum
enum, bind(C) ! cusparseMatrixType_t
enumerator :: CUSPARSE_MATRIX_TYPE_GENERAL = 0
enumerator :: CUSPARSE_MATRIX_TYPE_SYMMETRIC = 1
enumerator :: CUSPARSE_MATRIX_TYPE_HERMITIAN = 2
enumerator :: CUSPARSE_MATRIX_TYPE_TRIANGULAR = 3
end enum
enum, bind(C) ! cusparseIndexBase_t
enumerator :: CUSPARSE_INDEX_BASE_ZERO = 0
enumerator :: CUSPARSE_INDEX_BASE_ONE = 1
end enum
enum, bind(C) ! cusparseDirection_t
enumerator :: CUSPARSE_DIRECTION_ROW = 0
enumerator :: CUSPARSE_DIRECTION_COLUMN = 1
end enum
enum, bind(C) ! cusparseOperation_t
enumerator :: CUSPARSE_OPERATION_NON_TRANSPOSE = 0
enumerator :: CUSPARSE_OPERATION_TRANSPOSE = 1
enumerator :: CUSPARSE_OPERATION_CONJUGATE_TRANSPOSE = 2
end enum
type cusparseHandle
type(c_ptr) :: handle
end type cusparseHandle
type cusparseMatDescr
type(c_ptr) :: descr
end type cusparseMatDescr
type cusparseSolveAnalysisInfo
type(c_ptr) :: info
end type cusparseSolveAnalysisInfo
interface cusparseCreate
integer function cusparseCreate(handle) &
bind(C,name="cusparseCreate")
use iso_c_binding
import cusparseHandle
implicit none
type(cusparseHandle) :: handle
end function cusparseCreate
end interface
interface cusparseGetVersion
integer function cusparseGetVersion(handle, version) &
bind(C,name="cusparseGetVersion")
use iso_c_binding
implicit none
integer(c_int) :: version
end function cusparseGetVersion
end interface
interface cusparseCreateMatDescr
integer function cusparseCreateMatDescr(descr) &
bind(C,name="cusparseCreateMatDescr")
use iso_c_binding
import cusparseMatDescr
implicit none
type(cusparseMatDescr) :: descr
end function cusparseCreateMatDescr
end interface
interface cusparseSetMatType
integer function cusparseSetMatType(descr, type) &
bind(C,name="cusparseSetMatType")
use iso_c_binding
implicit none
integer(c_int) :: type
end function cusparseSetMatType
end interface
interface cusparseSetMatIndexBase
integer function cusparseSetMatIndexBase(descr, base) &
use iso_c_binding
implicit none
integer(c_int) :: base
end function cusparseSetMatIndexBase
end interface
interface cusparseCreateSolveAnalysisInfo
integer function cusparseCreateSolveAnalysisInfo(info) &
use iso_c_binding
import cusparseSolveAnalysisInfo
implicit none
type(cusparseSolveAnalysisInfo) :: info
end function cusparseCreateSolveAnalysisInfo
end interface
interface cusparseDestroy
integer function cusparseDestroy(handle) &
bind(C,name="cusparseDestroy")
use iso_c_binding
implicit none
end function cusparseDestroy
end interface
interface cusparseDnnz
integer function cusparseDnnz(handle, dirA, m, n, descr, Aval, lda, &
nnzPRC, nnzTDHP) bind(C,name="cusparseDnnz")
use iso_c_binding
implicit none
integer(c_int) :: dirA, m, n, lda, nnzTDHP
integer(c_int), device :: nnzPRC(:)
real(c_double), device :: Aval(:,:)
end function cusparseDnnz
end interface
interface cusparseDdense2csr
integer function cusparseDdense2csr(handle, m, n, descr, Aval, lda, &
nnzPR, csrValA, csrRowPA, csrColIA) bind(C,name="cusparseDdense2csr")
use iso_c_binding
implicit none
integer(c_int) :: m, n, lda, nnzTDHP
integer(c_int), device :: nnzPR(:), csrRowPA(:), csrColIA(:)
real(c_double), device :: Aval(:,:), csrValA(:)
end function cusparseDdense2csr
end interface
interface cusparseDcsrmm
integer function cusparseDcsrmm(handle, transA, m, n, k, nnz, alpha, descr, &
csrValA, csrRowPA, csrColIA, B, ldb, beta, C, ldc) bind(C,name="cusparseDcsrmm")
use iso_c_binding
implicit none
integer(c_int) :: transA, m, n, k, nnz, ldb, ldc
real(c_double) :: alpha, beta
integer(c_int), device :: csrRowPA(:), csrColIA(:)
real(c_double), device :: B(:,:), C(:,:), csrValA(:)
end function cusparseDcsrmm
end interface
end module cusparse_m
! Compile with "pgfortran testLevel3.cuf -lcusparse"
program testLevel3
use cudafor
use cusparse_m
implicit none
integer, parameter :: nd=20 ! # rows/cols in dense matrix
type(cusparseMatDescr) :: descrA
type(cusparseSolveAnalysisInfo) :: saInfo
integer :: status, version, mode, i
! D-data
! dense
real(8) :: DAde(nd,nd), DBde(nd,nd), DCde(nd,nd), DmaxErr
real(8), device :: DAde_d(nd,nd), DBde_d(nd,nd), DCde_d(nd,nd)
! csr
real(8) :: csrValDA(nd)
real(8), device :: csrValDA_d(nd)
real(8) :: Dalpha, Dbeta
real(8), device :: Dalpha_d, Dbeta_d
! integer data common to all data types
integer :: nnz
integer :: nnzPerRowA(nd), csrRowPtrA(nd+1), csrColIndA(nd)
integer, device :: nnzPerRowA_d(nd), csrRowPtrA_d(nd+1), csrColInda_d(nd)
! Initialization
status = cusparseCreate(h)
write(*,*) '1', status
status = cusparseGetVersion(h, version)
write(*,*) '2', status
status = cusparseCreateMatDescr(descrA)
write(*,*) '3', status
status = cusparseSetMatType(descrA,CUSPARSE_MATRIX_TYPE_GENERAL)
write(*,*) '4', status
status = cusparseSetMatIndexBase(descrA,CUSPARSE_INDEX_BASE_ONE)
write(*,*) '5', status
status = cusparseCreateSolveAnalysisInfo(saInfo)
write(*,*) '6', status
! Initialize matrix (Identity)
DAde = 0.0
do i = 1, nd
DAde(i,i) = 1.0
end do
DAde_d = DAde
call random_number(DBde)
DBde_d = DBde
! convert from dense to csr
status = cusparseDnnz(h, CUSPARSE_DIRECTION_ROW, nd, nd, descrA, &
DAde_d, nd, nnzPerRowA_d, nnz)
status = cusparseDdense2csr(h, nd, nd, descrA, DAde_d, nd, nnzPerRowA_d, &
csrValDA_d, csrRowPtrA_d, csrColIndA_d)
! csrmm HPM
Dalpha = 1.0
Dbeta = 0.0
status = cusparseDcsrmm(h, CUSPARSE_OPERATION_NON_TRANSPOSE, nd, nd, nd, &
nnz, Dalpha, descrA, csrValDA_d, csrRowPtrA_d, csrColIndA_d, DBde_d, &
nd, Dbeta, DCde_d, nd)
if (status /= CUSPARSE_STATUS_SUCCESS) write (*,*) 'CSRMM Error:', status
DCde = DCde_d
DmaxErr = maxval(abs(DCde-DBde))
status = cusparseDestroy(h)
write(*,*) 'cusparseDestroy', status, DmaxErr
end program testLevel3
After compiling this code, you can see the following result.
1 0
2 1
3 0
4 3
5 3
6 0
CSRMM Error : 1
