I use cvQueryframe for rtsp,but the effective is low.Is it soft codec or hard codec?
WayneWWW
2
Hi libin198783,
How do you use rtsp in opencv4tegra? Could you share the code?
Related topics
| decode the rtsp stream from a IP camera | 25 | 10069 | November 11, 2019 | |
| Jetson TX2 RTSP Streaming, FFmpeg or Gstreamer? | 8 | 10220 | November 17, 2021 | |
| the cpu usage cannot down (use cuda decode) | 29 | 12042 | October 18, 2021 | |
| TX2 decide H264 with tegra_multimedia_api | 34 | 2525 | October 18, 2021 | |
| TX2 tegra_multimedia_api encode/decode issue | 19 | 2449 | October 18, 2021 | |
| Pass argument for the codec to display | 1 | 468 | June 6, 2021 | |
| Problems about the image resolution of rtsp stream | 18 | 347 | December 14, 2024 | |
| TX2 H264 RTSP Stream decoding issues | 27 | 12032 | October 18, 2021 | |
| capture + encode on TX2 | 10 | 2288 | October 18, 2021 | |
| Is there a way to use OPENCV? | 2 | 997 | October 18, 2021 |
