- I compiled OpenCV 3.2.0 with hardware jpegencode from nvidia.
-- ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
-- JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
-- WEBP: /usr/lib/aarch64-linux-gnu/libwebp.so (ver encoder: 0x0202)
-- PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
-- TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 - 4.0.6)
-- JPEG 2000: /usr/lib/aarch64-linux-gnu/libjasper.so (ver 1.900.1)
After installed the lib. I could imread(“test.jpg”) with opencv and imshow() the image in windows.
For jpeg file read and show with opencv works fine.
while(1) {
Mat frame = imread("/home/ubuntu/tegra_multimedia_api/samples/13_camera_v4l2_jpeg/output0.jpg");
printf("%d %d", frame.cols, frame.rows);
if (frame.data)
printf("good");
imshow("test", frame);
waitKey(30);
But I can not open the camera with VideoCapture(0) to preivew.
VideoCapture capture;
Mat image;
capture.open(0);
if(capture.isOpened())
cout << "Capture is opened" << endl;
for(;;)
capture >> image;
cout << "====%d\n" << image.cols<< endl;
if(image.empty())
break;
// drawText(image);
imshow("Sample", image);
if(waitKey(10) >= 0)
break;
else
cout << "No capture" << endl;
image = Mat::zeros(480, 640, CV_8UC1);
//drawText(image);
waitKey(0);
return 0;
The log from console.
[ 4095.166564] pixelformat : YUV UYVY 2X8 4:2:2 tegra_core_get_format_by_fourcc, drivers/media/platform/tegra/camera/core.c, 381
[ 4095.178050] pixelformat :YUV UYVY 2X8 4:2:2 code:0x00002006 __tegra_channel_set_format, drivers/media/platform/tegra/camera/channel.c, 1397
[ 4095.190752] ov5640 30-003c: camera_common_try_fmt: size 1920 x 1080
[ 4095.197021] ov5640 30-003c: camera_common_try_fmt: w: 1920, h:1080, maxframerate: 30, s_data->mode: 0, code: 0x00002006
[ 4095.208548] ov5640 30-003c: camera_common_s_fmt(0x00002006) size 1920 x 1080, colorfmt:1498831189
[ 4095.229817] vb2_streamon, drivers/media/v4l2-core/videobuf2-core.c, 1708
[ 4095.236810] =============== bypass : 0 ===============================================
[ 4095.236810]
[ 4095.246874] port_num: 0 drivers/media/platform/tegra/csi/csi.c, tegra_csi_start_streaming, 253
[ 4095.255826] vi vi: csi2_write:port 0 offset 0x00000218 val:0x00000000
[ 4095.262765] vi vi: csi2_read:port 0 offset 0x000000d0
[ 4095.267910] vi vi: csi2_write:port 0 offset 0x000000d0 val:0x00000001
[ 4095.290597] (NULL device *): camera_common_dpd_disable: csi 0
[ 4095.296500] ov5640 30-003c: ov5640_s_stream++
[ 4095.390247] ov5640 30-003c: ov5640_write_table: ret = 0
[ 4095.396231] ov5640 30-003c: ov5640_set_gain: gain 0100 val: 0010
[ 4095.420501] ov5640 30-003c: ov5640_write_table: ret = 0
[ 4095.425730] ov5640 30-003c: ov5640_s_stream--
[ 4095.490532] smmu_dump_pagetable(): fault_address=0x0000000080352000 pa=0x0000000000000000 bytes=1000 #pte=533 in L2
[ 4095.501004] mc-err: (18) csw_viw: EMEM decode error on PDE or PTE entry
[ 4095.507628] mc-err: status = 0x60010072; addr = 0x80352000
[ 4095.513333] mc-err: secure: no, access-type: write, SMMU fault: nr-nw-s
[ 4095.523864] smmu_dump_pagetable(): fault_address=0x0000000080552000 pa=0x0000000000000000 bytes=1000 #pte=676 in L2
[ 4095.534337] mc-err: (18) csw_viw: EMEM decode error on PDE or PTE entry
[ 4095.540987] mc-err: status = 0x60010072; addr = 0x80552000
[ 4095.546648] mc-err: secure: no, access-type: write, SMMU fault: nr-nw-s
[ 4095.557195] smmu_dump_pagetable(): fault_address=0x0000000080752000 pa=0x0000000000000000 bytes=1000 #pte=676 in L2
[ 4095.567676] mc-err: (18) csw_viw: EMEM decode error on PDE or PTE entry
[ 4095.574339] mc-err: status = 0x60010072; addr = 0x80752000
[ 4095.578812] pgd = ffffffc081768000
[ 4095.578816] [0078fa42] *pgd=0000000125d6b003, *pmd=00000001361f1003, *pte=0000000000000000
[ 4095.578866] pgd = ffffffc081768000
[ 4095.578872] [00775002] *pgd=0000000125d6b003, *pmd=00000001361f1003
[ 4095.578905] Library at 0x7f87befcb4: 0x7f87a67000 /usr/local/lib/libopencv_imgproc.so.3.2.0
[ 4095.578909] Library at 0x7f88b46710: 0x7f88aee000 /usr/local/lib/libopencv_core.so.3.2.0
[ 4095.578911] vdso base = 0x7f88f78000
[ 4095.578944] Library at 0x7f87befcb4: 0x7f87a67000 /usr/local/lib/libopencv_imgproc.so.3.2.0
[ 4095.578947] Library at 0x7f88b46710: 0x7f88aee000 /usr/local/lib/libopencv_core.so.3.2.0
[ 4095.578948] vdso base = 0x7f88f78000
[ 4095.641358] mc-err: secure: no, access-type: write, SMMU fault: nr-nw-s
[ 4095.657202] smmu_dump_pagetable(): fault_address=0x0000000080552000 pa=0x0000000000000000 bytes=1000 #pte=676 in L2
[ 4095.667728] mc-err: (18) csw_viw: EMEM decode error on PDE or PTE entry
[ 4095.674416] mc-err: status = 0x60010072; addr = 0x80552000
[ 4095.680077] mc-err: secure: no, access-type: write, SMMU fault: nr-nw-s
[ 4095.695074] port_num: 0 drivers/media/platform/tegra/csi/csi.c, tegra_csi_stop_streaming, 282
[ 4095.709626] (NULL device *): camera_common_dpd_enable: csi 0
[ 4095.715339] ov5640 30-003c: ov5640_s_stream++
[ 4095.737626] ov5640 30-003c: ov5640_write_table: ret = 0
[ 4095.744485] (NULL device *): camera_common_dpd_enable: csi 0
[ 4095.750158] ov5640 30-003c: ov5640_power_off: power off
[ 4095.777994] ov5640 30-003c: camera_common_mclk_disable: disable MCLK
The error log from shell termainal.
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/13_camera_v4l2_jpeg/build/build$ ./camera
Capture is opened
Segmentation fault
I could preview with
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=300 ! 'video/x-raw,width=1920,height=1080,format=(string)UYVY' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! nvoverlaysink
Also I could get a jpeg with
gst-launch-1.0 v4l2src device="dev/video0" num-buffers=1 ! "video/x-raw, width=1920, height=1080, format=I420" ! nvjpegenc ! filesink location=test.jpg -e
The whole opencv configure.
-- General configuration for OpenCV 3.2.0-dev =====================================
-- Version control: 3.2.0-1-g7dd3723-dirty
-- Extra modules:
-- Location (extra): /media/ubuntu/91df5a31-05fd-4885-b29b-d7e625107ac5/opencv/opencv_contrib/modules
-- Version control (extra): 3.2.0
-- Platform:
-- Timestamp: 2017-01-06T03:38:25Z
-- Host: Linux 3.10.96-tegra aarch64
-- CMake: 3.5.1
-- CMake generator: Unix Makefiles
-- CMake build tool: /usr/bin/make
-- Configuration: RELEASE
-- C/C++:
-- Built as dynamic libs?: YES
-- C++ Compiler: /usr/bin/c++ (ver 5.4.0)
-- C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
-- C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
-- C Compiler: /usr/bin/cc
-- C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
-- C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
-- Linker flags (Release):
-- Linker flags (Debug):
-- ccache: NO
-- Precompiled headers: YES
-- Extra dependencies: /usr/lib/aarch64-linux-gnu/libwebp.so /usr/lib/aarch64-linux-gnu/libjasper.so gtk-x11-2.0 gdk-x11-2.0 pangocairo-1.0 atk-1.0 cairo gdk_pixbuf-2.0 gio-2.0 pangoft2-1.0 pango-1.0 gobject-2.0 glib-2.0 fontconfig freetype gthread-2.0 gtkglext-x11-1.0 gdkglext-x11-1.0 GLU GL Xmu Xt SM ICE pangox-1.0 X11 gmodule-2.0 gstbase-1.0 gstreamer-1.0 gstvideo-1.0 gstapp-1.0 gstriff-1.0 gstpbutils-1.0 dc1394 avcodec-ffmpeg avformat-ffmpeg avutil-ffmpeg swscale-ffmpeg /usr/lib/aarch64-linux-gnu/hdf5/serial/lib/libhdf5.so /usr/lib/aarch64-linux-gnu/libpthread.so /usr/lib/aarch64-linux-gnu/libsz.so /usr/lib/aarch64-linux-gnu/libdl.so /usr/lib/aarch64-linux-gnu/libm.so vtkRenderingOpenGL vtkImagingHybrid vtkIOImage vtkCommonDataModel vtkCommonMath vtkCommonCore vtksys vtkCommonMisc vtkCommonSystem vtkCommonTransforms vtkCommonExecutionModel vtkDICOMParser vtkIOCore /usr/lib/aarch64-linux-gnu/libz.so vtkmetaio /usr/lib/aarch64-linux-gnu/libjpeg.so /usr/lib/aarch64-linux-gnu/libpng.so /usr/lib/aarch64-linux-gnu/libtiff.so vtkImagingCore vtkRenderingCore vtkCommonColor vtkFiltersExtraction vtkFiltersCore vtkFiltersGeneral vtkCommonComputationalGeometry vtkFiltersStatistics vtkImagingFourier vtkalglib vtkFiltersGeometry vtkFiltersSources vtkInteractionStyle vtkRenderingLOD vtkFiltersModeling vtkIOPLY vtkIOGeometry /usr/lib/aarch64-linux-gnu/libjsoncpp.so vtkFiltersTexture vtkRenderingFreeType /usr/lib/aarch64-linux-gnu/libfreetype.so vtkftgl vtkIOExport vtkRenderingAnnotation vtkImagingColor vtkRenderingContext2D vtkRenderingGL2PS vtkRenderingContextOpenGL /usr/lib/libgl2ps.so vtkRenderingLabel dl m pthread rt /usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so cudart nppc nppi npps cufft -L/usr/local/cuda-8.0/lib64
-- 3rdparty dependencies: IlmImf tegra_hal
-- OpenCV modules:
-- To be built: cudev core cudaarithm flann hdf imgproc ml reg surface_matching video viz cudabgsegm cudafilters cudaimgproc cudawarping freetype fuzzy imgcodecs photo shape videoio cudacodec highgui objdetect plot ts xobjdetect xphoto bgsegm bioinspired dpm face features2d line_descriptor saliency text calib3d ccalib cudafeatures2d cudalegacy cudaobjdetect cudaoptflow cudastereo datasets rgbd stereo superres videostab xfeatures2d ximgproc aruco optflow phase_unwrapping stitching structured_light java python2 python3
-- Disabled: world contrib_world
-- Disabled by dependency: tracking
-- Unavailable: cnn_3dobj cvv dnn matlab sfm
-- GUI:
-- QT: NO
-- GTK+ 2.x: YES (ver 2.24.30)
-- GThread : YES (ver 2.48.1)
-- GtkGlExt: YES (ver 1.2.0)
-- OpenGL support: YES (/usr/lib/aarch64-linux-gnu/libGLU.so /usr/lib/aarch64-linux-gnu/libGL.so)
-- VTK support: YES (ver 6.2.0)
-- Media I/O:
-- OpenEXR: build (ver 1.7.1)
-- GDAL: NO
-- GDCM: NO
-- Video I/O:
-- DC1394 1.x: NO
-- DC1394 2.x: YES (ver 2.2.4)
-- FFMPEG: YES
-- avcodec: YES (ver 56.60.100)
-- avformat: YES (ver 56.40.101)
-- avutil: YES (ver 54.31.100)
-- swscale: YES (ver 3.1.101)
-- avresample: NO
-- GStreamer:
-- base: YES (ver 1.8.2)
-- video: YES (ver 1.8.2)
-- app: YES (ver 1.8.2)
-- riff: YES (ver 1.8.2)
-- pbutils: YES (ver 1.8.2)
-- OpenNI: NO
-- OpenNI PrimeSensor Modules: NO
-- OpenNI2: NO
-- PvAPI: NO
-- GigEVisionSDK: NO
-- Aravis SDK: NO
-- UniCap: NO
-- UniCap ucil: NO
-- V4L/V4L2: NO/YES
-- XIMEA: NO
-- Xine: NO
-- gPhoto2: NO
-- Parallel framework: pthreads
-- Other third-party libraries:
-- Use IPP: NO
-- Use VA: NO
-- Use Intel VA-API/OpenCL: NO
-- Use Lapack: NO
-- Use Eigen: YES (ver 3.2.92)
-- Use Cuda: YES (ver 8.0)
-- Use OpenCL: YES
-- Use OpenVX: NO
-- Use custom HAL: YES (carotene (ver 0.0.1))
-- NVIDIA CUDA
-- Use CUFFT: YES
-- Use CUBLAS: NO
-- USE NVCUVID: NO
-- NVIDIA GPU arch: 53
-- NVIDIA PTX archs:
-- Use fast math: NO
-- OpenCL: <Dynamic loading of OpenCL library>
-- Include path: /media/ubuntu/91df5a31-05fd-4885-b29b-d7e625107ac5/opencv/opencv/3rdparty/include/opencl/1.2
-- Use AMDFFT: NO
-- Use AMDBLAS: NO
-- Python 2:
-- Interpreter: /usr/bin/python2.7 (ver 2.7.12)
-- Libraries: /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.12)
-- numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.11.0)
-- packages path: lib/python2.7/dist-packages
-- Python 3:
-- Interpreter: /usr/bin/python3 (ver 3.5.2)
-- Libraries: /usr/lib/aarch64-linux-gnu/libpython3.5m.so (ver 3.5.2)
-- numpy: /usr/local/lib/python3.5/dist-packages/numpy/core/include (ver 1.11.3)
-- packages path: lib/python3.5/dist-packages
-- Python (for build): /usr/bin/python3
-- Java:
-- ant: /usr/bin/ant (ver 1.9.6)
-- JNI: /usr/lib/jvm/java-8-oracle/include /usr/lib/jvm/java-8-oracle/include/linux /usr/lib/jvm/java-8-oracle/include
-- Java wrappers: YES
-- Java tests: YES
-- Matlab: Matlab not found or implicitly disabled
-- Documentation:
-- Doxygen: NO
-- Tests and samples:
-- Tests: YES
-- Performance tests: YES
-- C/C++ Examples: YES
-- Install path: /usr/local
-- cvconfig.h is in: /media/ubuntu/91df5a31-05fd-4885-b29b-d7e625107ac5/opencv/opencv/test_example
-- Configuring done
I test the tegra_multimedia_api sample 13. It works fine. I think the jpeg decoder work fine. but can not be used by opencv. refer to topic.
https://devtalk.nvidia.com/default/topic/984850/jetson-tx1/how-to-convert-yuv-to-jpg-using-jpeg-encoder-hardware-/
Questions:
How could I got it work with opencv?
