Hi, DaneLLL
I set the GST_DEBUG=4 and get more information. The key problem should be the format UYVY. It’s not supportted by omx.
ubuntu@tegra-ubuntu:/media/ubuntu/91df5a31-05fd-4885-b29b-d7e625107ac51$ gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=300 ! 'video/x-raw,width=1920,height=1080' ! nvvidconv ! nvoverlaysink
0:00:00.000422031 3297 0x426800 INFO GST_INIT gst.c:511:init_pre: Initializing GStreamer Core Library version 1.8.2
0:00:00.001045469 3297 0x426800 INFO GST_INIT gst.c:512:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.001227188 3297 0x426800 INFO GST_INIT gst.c:523:init_pre: Linux tegra-ubuntu 3.10.96-tegra #150 SMP PREEMPT Tue Jan 3 18:27:42 CST 2017 aarch64
0:00:00.003272708 3297 0x426800 INFO GST_INIT gstmessage.c:119:_priv_gst_message_initialize: init messages
0:00:00.007496094 3297 0x426800 INFO GST_INIT gstcontext.c:83:_priv_gst_context_initialize: init contexts
0:00:00.009454219 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.010489167 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.010643177 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.010861198 3297 0x426800 INFO GST_REGISTRY gstregistry.c:1723:ensure_current_registry: reading registry cache: /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.057514427 3297 0x426800 INFO GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache: loaded /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin in 0.046452 seconds
0:00:00.057655729 3297 0x426800 INFO GST_REGISTRY gstregistry.c:1579:scan_and_update_registry: Validating plugins from registry cache: /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.059190365 3297 0x426800 INFO GST_REGISTRY gstregistry.c:1681:scan_and_update_registry: Registry cache has not changed
0:00:00.059228125 3297 0x426800 INFO GST_REGISTRY gstregistry.c:1758:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.059255521 3297 0x426800 INFO GST_INIT gst.c:724:init_post: GLib runtime version: 2.48.1
0:00:00.059284323 3297 0x426800 INFO GST_INIT gst.c:726:init_post: GLib headers version: 2.48.1
0:00:00.059310729 3297 0x426800 INFO GST_INIT gst.c:727:init_post: initialized GStreamer successfully
0:00:00.059386094 3297 0x426800 INFO GST_PIPELINE gstparse.c:323:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 num-buffers=300 ! video/x-raw,width=1920,height=1080 ! nvvidconv ! nvoverlaysink '
0:00:00.062911302 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" loaded
0:00:00.062972240 3297 0x426800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "v4l2src"
0:00:00.064758073 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSrc@0x59e2f0> adding pad 'src'
0:00:00.067308698 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.067363229 3297 0x426800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvvidconv"
0:00:00.067665156 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5a66d0> adding pad 'sink'
0:00:00.067722292 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5a66d0> adding pad 'src'
0:00:00.074781823 3297 0x426800 WARN omx gstomx.c:2839:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/ubuntu/.config:/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:00.074837552 3297 0x426800 INFO omx gstomx.c:2844:plugin_init: Using default configuration
0:00:00.075978437 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so" loaded
0:00:00.076018021 3297 0x426800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvoverlaysink"
0:00:00.076313073 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x5ba5b0> adding pad 'sink'
0:00:00.076382656 3297 0x426800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "pipeline"
0:00:00.076652292 3297 0x426800 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstV4l2Src named v4l2src0 to some pad of Gstnvvconv named nvvconv0 (0/0) with caps "video/x-raw, width=(int)1920, height=(int)1080"
0:00:00.077633021 3297 0x426800 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.077674062 3297 0x426800 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "capsfilter"
0:00:00.077854115 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5c23d0> adding pad 'sink'
0:00:00.077946562 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5c23d0> adding pad 'src'
0:00:00.077993437 3297 0x426800 INFO GST_STATES gstbin.c:1915:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.078046719 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.078088750 3297 0x426800 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.078132552 3297 0x426800 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.078173229 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.078202760 3297 0x426800 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.078257344 3297 0x426800 INFO GST_PADS gstpad.c:2313:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.078319219 3297 0x426800 INFO GST_PADS gstpad.c:4087:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.078363594 3297 0x426800 INFO GST_PADS gstpad.c:2519:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.078396250 3297 0x426800 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.078424740 3297 0x426800 INFO GST_EVENT gstpad.c:5623:gst_pad_send_event_unchecked:<v4l2src0:src> Received event on flushing pad. Discarding
0:00:00.078461771 3297 0x426800 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element capsfilter0:src to element nvvconv0:(any)
0:00:00.078530729 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.078563854 3297 0x426800 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.078631250 3297 0x426800 INFO GST_PADS gstpad.c:4087:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.078813490 3297 0x426800 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: capsfilter0 and nvvconv0 in same bin, no need for ghost pads
0:00:00.078855521 3297 0x426800 INFO GST_PADS gstpad.c:2313:gst_pad_link_prepare: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.078917031 3297 0x426800 INFO GST_PADS gstpad.c:4087:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.079039635 3297 0x426800 INFO GST_PADS gstpad.c:2519:gst_pad_link_full: linked capsfilter0:src and nvvconv0:sink, successful
0:00:00.079071667 3297 0x426800 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.079097500 3297 0x426800 INFO GST_EVENT gstpad.c:5623:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.079131823 3297 0x426800 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of Gstnvvconv named nvvconv0 to some pad of GstNvOverlaySink-nvoverlaysink named nvoverlaysink-nvoverlaysink0 (0/0) with caps "(NULL)"
0:00:00.079175000 3297 0x426800 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element nvvconv0:(any) to element nvoverlaysink-nvoverlaysink0:(any)
0:00:00.079207031 3297 0x426800 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link nvvconv0:src and nvoverlaysink-nvoverlaysink0:sink
0:00:00.079429948 3297 0x426800 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: nvvconv0 and nvoverlaysink-nvoverlaysink0 in same bin, no need for ghost pads
0:00:00.079507760 3297 0x426800 INFO GST_PADS gstpad.c:2313:gst_pad_link_prepare: trying to link nvvconv0:src and nvoverlaysink-nvoverlaysink0:sink
0:00:00.079672917 3297 0x426800 INFO GST_PADS gstpad.c:2519:gst_pad_link_full: linked nvvconv0:src and nvoverlaysink-nvoverlaysink0:sink, successful
0:00:00.079705000 3297 0x426800 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.079730365 3297 0x426800 INFO GST_EVENT gstpad.c:5623:gst_pad_send_event_unchecked:<nvvconv0:src> Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.079840052 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current NULL pending VOID_PENDING, desired next READY
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and Mjstreaming0:00:00.092353802 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvoverlaysink-nvoverlaysink0> completed state change to READY
0:00:00.092402500 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvoverlaysink-nvoverlaysink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.092470208 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' changed state to 2(READY) successfully
0:00:00.092518333 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current NULL pending VOID_PENDING, desired next READY
0:00:00.092560260 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:00.092588958 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.092624427 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:00.092661094 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.092693385 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.092720052 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.092753437 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.092786719 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<v4l2src0> current NULL pending VOID_PENDING, desired next READY
libv4lconvert: warning more framesizes then I can handle!
0:00:00.155535521 3297 0x426800 INFO v4l2 v4l2_calls.c:587:gst_v4l2_open:<v4l2src0> Opened device 'vi-output-0, ov5640 30-003c' (/dev/video0) successfully
0:00:00.155634427 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to READY
0:00:00.155720990 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.155770573 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
0:00:00.155816458 3297 0x426800 INFO GST_STATES gstelement.c:2347:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.155847448 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.155927760 3297 0x426800 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.155982135 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.156040885 3297 0x426800 INFO GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' is changing state asynchronously to PAUSED
0:00:00.156078333 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.156134792 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:00.156165417 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.156202083 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:00.156236771 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.156306406 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.156334479 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.156391198 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.156424531 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<v4l2src0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.156518125 3297 0x426800 INFO basesrc gstbasesrc.c:1344:gst_base_src_do_seek:<v4l2src0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.156592969 3297 0x426800 INFO task gsttask.c:451:gst_task_set_lock: setting stream lock 0x5a00a0 on task 0x4d5050
0:00:00.156626406 3297 0x426800 INFO GST_PADS gstpad.c:5969:gst_pad_start_task:<v4l2src0:src> created task 0x4d5050
0:00:00.156745260 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to PAUSED
0:00:00.156783073 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.156821250 3297 0x426800 INFO GST_STATES gstbin.c:2807:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 3(PAUSED) successfully without preroll
0:00:00.156862500 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:00.156901979 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.156874740 3297 0x5c1050 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad 'sink' in element "v4l2src0"
Pipeline is live and does not need PREROLL ...
0:00:00.157264635 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1143:gst_v4l2_object_fill_format_list:<v4l2src0> got 5 format(s):
0:00:00.157305052 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1149:gst_v4l2_object_fill_format_list:<v4l2src0> UYVY
0:00:00.157339740 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1149:gst_v4l2_object_fill_format_list:<v4l2src0> YU12 (emulated)
0:00:00.157370521 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1149:gst_v4l2_object_fill_format_list:<v4l2src0> YV12 (emulated)
0:00:00.157400417 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1149:gst_v4l2_object_fill_format_list:<v4l2src0> BGR3 (emulated)
0:00:00.157428281 3297 0x5c1050 INFO v4l2 gstv4l2object.c:1149:gst_v4l2_object_fill_format_list:<v4l2src0> RGB3 (emulated)
0:00:00.157472448 3297 0x5c1050 WARN v4l2 gstv4l2object.c:2618:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Unknown frame sizeenum type for pixelformat UYVY: 0
Setting pipeline to PLAYING ...
0:00:00.157849010 3297 0x426800 INFO GST_EVENT gstevent.c:1253:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.157938385 3297 0x426800 INFO bin gstbin.c:2593:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.158071458 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current READY pending PAUSED, desired next PLAYING
0:00:00.158104844 3297 0x426800 INFO GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' is changing state asynchronously to PLAYING
0:00:00.158137656 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.158170677 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to PLAYING
0:00:00.158197917 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.158232812 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:00.158267656 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.158298750 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:00.158325052 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.158358594 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.158395573 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to PLAYING
0:00:00.158423073 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.158456302 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 4(PLAYING) successfully
New clock: GstSystemClock
0:00:01.167228281 3297 0x5c1050 WARN v4l2 gstv4l2object.c:2618:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Unknown frame sizeenum type for pixelformat YU12: 0
0:00:02.579168332 3297 0x5c1050 WARN v4l2 gstv4l2object.c:2618:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Unknown frame sizeenum type for pixelformat YV12: 0
0:00:03.990961769 3297 0x5c1050 WARN v4l2 gstv4l2object.c:2618:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Unknown frame sizeenum type for pixelformat BGR3: 0
0:00:05.402383904 3297 0x5c1050 WARN v4l2 gstv4l2object.c:2618:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Unknown frame sizeenum type for pixelformat RGB3: 0
0:00:06.813142654 3297 0x5c1050 INFO v4l2 gstv4l2object.c:3811:gst_v4l2_object_get_caps:<v4l2src0> probed caps: video/x-raw, format=(string)UYVY, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1; video/x-raw, format=(string)I420, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1; video/x-raw, format=(string)YV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1; video/x-raw, format=(string)BGR, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB; video/x-raw, format=(string)RGB, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB
0:00:07.410417237 3297 0x5c1050 INFO v4l2 gstv4l2object.c:2777:gst_v4l2_object_setup_pool:<v4l2src0> accessing buffers via mode 2
0:00:07.410742028 3297 0x5c1050 INFO v4l2bufferpool gstv4l2bufferpool.c:551:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool:src> increasing minimum buffers to 2
0:00:07.410790987 3297 0x5c1050 INFO v4l2bufferpool gstv4l2bufferpool.c:564:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool:src> reducing maximum buffers to 32
0:00:07.410854424 3297 0x5c1050 INFO GST_EVENT gstevent.c:679:gst_event_new_caps: creating caps event video/x-raw, format=(string)UYVY, framerate=(fraction)100/1, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1
0:00:07.410993591 3297 0x5c1050 INFO basetransform gstbasetransform.c:1367:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:07.411031612 3297 0x5c1050 INFO GST_EVENT gstevent.c:679:gst_event_new_caps: creating caps event video/x-raw, format=(string)UYVY, framerate=(fraction)100/1, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1
0:00:07.411438747 3297 0x5c1050 INFO GST_EVENT gstevent.c:679:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), framerate=(fraction)100/1, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, format=(string)UYVY
0:00:07.411530622 3297 0x5c1050 ERROR omxvideosink gstomxvideosink.c:1188:gst_omx_video_sink_setcaps:<nvoverlaysink-nvoverlaysink0> Unsupported format UYVY
0:00:07.411588799 3297 0x5c1050 ERROR omxvideosink gstomxvideosink.c:1188:gst_omx_video_sink_setcaps:<nvoverlaysink-nvoverlaysink0> Unsupported format UYVY
0:00:07.411621560 3297 0x5c1050 WARN GST_PADS gstpad.c:4081:gst_pad_peer_query:<nvvconv0:src> could not send sticky events
0:00:07.411757706 3297 0x5c1050 INFO v4l2bufferpool gstv4l2bufferpool.c:564:gst_v4l2_buffer_pool_set_config:<v4l2src0:pool:src> reducing maximum buffers to 32
0:00:07.430629372 3297 0x5c1050 WARN v4l2bufferpool gstv4l2bufferpool.c:748:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:07.646777028 3297 0x5c1050 INFO v4l2src gstv4l2src.c:843:gst_v4l2src_create:<v4l2src0> sync to 0:00:00.010000000 out ts 0:00:07.420895252
0:00:07.647624060 3297 0x5c1050 INFO GST_EVENT gstevent.c:760:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:07.649151612 3297 0x5c1050 ERROR omxvideosink gstomxvideosink.c:1188:gst_omx_video_sink_setcaps:<nvoverlaysink-nvoverlaysink0> Unsupported format UYVY
0:00:07.649850883 3297 0x5c1050 INFO basesrc gstbasesrc.c:2843:gst_base_src_loop:<v4l2src0> marking pending DISCONT
0:00:07.688441403 3297 0x5c1050 ERROR omxvideosink gstomxvideosink.c:1188:gst_omx_video_sink_setcaps:<nvoverlaysink-nvoverlaysink0> Unsupported format UYVY
0:00:07.688565570 3297 0x5c1050 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<v4l2src0> error: Internal data flow error.
0:00:07.688624060 3297 0x5c1050 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<v4l2src0> error: streaming task paused, reason not-negotiated (-4)
0:00:07.688686924 3297 0x5c1050 INFO GST_ERROR_SYSTEM gstelement.c:1879:gst_element_message_full:<v4l2src0> posting message: Internal data flow error.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Execution ended after 0:00:07.530536247
0:00:07.689085310 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current READY pending PAUSED, desired next PAUSED
0:00:07.689118903 3297 0x426800 INFO GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' is changing state asynchronously to PAUSED
0:00:07.689150622 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:07.689181612 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:07.689203799 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:07.689243955 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:07.689276351 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:07.689303278 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:07.689323695 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:07.689353018 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:07.689381195 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<v4l2src0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:07.689417862 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to PAUSED
0:00:07.689439007 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:07.689468226 3297 0x426800 INFO GST_STATES gstbin.c:2807:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 3(PAUSED) successfully without preroll
0:00:07.689498278 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<pipeline0> completed state change to PAUSED
Setting pipeline to READY ...
0:00:07.689563643 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current READY pending PAUSED, desired next READY
0:00:07.689643330 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvoverlaysink-nvoverlaysink0> completed state change to READY
0:00:07.689667028 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvoverlaysink-nvoverlaysink0> notifying about state-changed READY to READY (VOID_PENDING pending)
0:00:07.689697914 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' changed state to 2(READY) successfully
0:00:07.689727185 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next READY
0:00:07.690350987 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:07.690390414 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:07.690430466 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:07.690466091 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next READY
0:00:07.690522132 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:07.690545466 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:07.690577862 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:07.694248695 3297 0x5c1050 INFO GST_ERROR_SYSTEM gstelement.c:1902:gst_element_message_full:<v4l2src0> posted error message: Internal data flow error.
0:00:07.694328695 3297 0x5c1050 INFO task gsttask.c:316:gst_task_func:<v4l2src0:src> Task going to paused
0:00:07.739247757 3297 0x5c1050 INFO task gsttask.c:318:gst_task_func:<v4l2src0:src> Task resume from paused
0:00:07.739475778 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to READY
0:00:07.739534893 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:07.739577601 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
0:00:07.739619216 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<pipeline0> completed state change to READY
0:00:07.739646768 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:07.739703799 3297 0x426800 INFO GST_STATES gstbin.c:1915:gst_bin_get_state_func:<pipeline0> getting state
Setting pipeline to NULL ...
0:00:07.739785726 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvoverlaysink-nvoverlaysink0> current READY pending VOID_PENDING, desired next NULL
0:00:07.739834476 3297 0x426800 INFO omx gstomx.c:758:gst_omx_component_free:<nvoverlaysink-nvoverlaysink0> Unloading component 0x4296e0 yuv420
0:00:07.739878018 3297 0x426800 INFO omx gstomx.c:1833:gst_omx_port_deallocate_buffers_unlocked:<nvoverlaysink-nvoverlaysink0> Deallocating buffers of yuv420 port 0
0:00:07.740100726 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvoverlaysink-nvoverlaysink0> completed state change to NULL
0:00:07.740139320 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvoverlaysink-nvoverlaysink0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:07.740182289 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvoverlaysink-nvoverlaysink0' changed state to 1(NULL) successfully
0:00:07.740219476 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next NULL
0:00:07.740259007 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0> completed state change to NULL
0:00:07.740286403 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:07.740319528 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 1(NULL) successfully
0:00:07.740353070 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next NULL
0:00:07.740401039 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:07.740434789 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:07.740474476 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
0:00:07.740506195 3297 0x426800 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<v4l2src0> current READY pending VOID_PENDING, desired next NULL
0:00:07.760692341 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<v4l2src0> completed state change to NULL
0:00:07.760758435 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<v4l2src0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:07.760822601 3297 0x426800 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 1(NULL) successfully
0:00:07.760907810 3297 0x426800 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<pipeline0> completed state change to NULL
0:00:07.760939476 3297 0x426800 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline ...
0:00:07.761010518 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2069:gst_pad_unlink: unlinking v4l2src0:src(0x5a0030) and capsfilter0:sink(0x5a0930)
0:00:07.761057185 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2123:gst_pad_unlink: unlinked v4l2src0:src and capsfilter0:sink
0:00:07.761098487 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2069:gst_pad_unlink: unlinking capsfilter0:src(0x5a0b70) and nvvconv0:sink(0x5a0270)
0:00:07.761150362 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2123:gst_pad_unlink: unlinked capsfilter0:src and nvvconv0:sink
0:00:07.761192341 3297 0x426800 INFO GST_PARENTAGE gstbin.c:1630:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
0:00:07.761240049 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2947:gst_element_dispose:<capsfilter0> dispose
0:00:07.761269424 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
0:00:07.761307914 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<capsfilter0> removing pad 'src'
0:00:07.761341612 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2992:gst_element_dispose:<capsfilter0> parent class dispose
0:00:07.761369112 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3023:gst_element_finalize:<capsfilter0> finalize
0:00:07.761394632 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3028:gst_element_finalize:<capsfilter0> finalize parent
0:00:07.761424060 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2069:gst_pad_unlink: unlinking nvvconv0:src(0x5a04b0) and nvoverlaysink-nvoverlaysink0:sink(0x5a06f0)
0:00:07.761463278 3297 0x426800 INFO GST_ELEMENT_PADS gstpad.c:2123:gst_pad_unlink: unlinked nvvconv0:src and nvoverlaysink-nvoverlaysink0:sink
0:00:07.761507445 3297 0x426800 INFO GST_PARENTAGE gstbin.c:1630:gst_bin_remove_func:<pipeline0> removed child "nvoverlaysink-nvoverlaysink0"
0:00:07.761545414 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2947:gst_element_dispose:<nvoverlaysink-nvoverlaysink0> dispose
0:00:07.761576247 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<nvoverlaysink-nvoverlaysink0> removing pad 'sink'
0:00:07.761610049 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2992:gst_element_dispose:<nvoverlaysink-nvoverlaysink0> parent class dispose
0:00:07.761638278 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3023:gst_element_finalize:<nvoverlaysink-nvoverlaysink0> finalize
0:00:07.761671039 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3028:gst_element_finalize:<nvoverlaysink-nvoverlaysink0> finalize parent
0:00:07.761714789 3297 0x426800 INFO GST_PARENTAGE gstbin.c:1630:gst_bin_remove_func:<pipeline0> removed child "nvvconv0"
0:00:07.761749164 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2947:gst_element_dispose:<nvvconv0> dispose
0:00:07.761775205 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<nvvconv0> removing pad 'sink'
0:00:07.761808799 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<nvvconv0> removing pad 'src'
0:00:07.761841976 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2992:gst_element_dispose:<nvvconv0> parent class dispose
0:00:07.761870622 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3023:gst_element_finalize:<nvvconv0> finalize
0:00:07.761896351 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3028:gst_element_finalize:<nvvconv0> finalize parent
0:00:07.761944632 3297 0x426800 INFO GST_PARENTAGE gstbin.c:1630:gst_bin_remove_func:<pipeline0> removed child "v4l2src0"
0:00:07.761988174 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2947:gst_element_dispose:<v4l2src0> dispose
0:00:07.762019789 3297 0x426800 INFO GST_ELEMENT_PADS gstelement.c:776:gst_element_remove_pad:<v4l2src0> removing pad 'src'
0:00:07.762051612 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2992:gst_element_dispose:<v4l2src0> parent class dispose
0:00:07.762080257 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3023:gst_element_finalize:<v4l2src0> finalize
0:00:07.762105362 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3028:gst_element_finalize:<v4l2src0> finalize parent
0:00:07.762131195 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2947:gst_element_dispose:<pipeline0> dispose
0:00:07.762179893 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:2992:gst_element_dispose:<pipeline0> parent class dispose
0:00:07.762209268 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3023:gst_element_finalize:<pipeline0> finalize
0:00:07.762233591 3297 0x426800 INFO GST_REFCOUNTING gstelement.c:3028:gst_element_finalize:<pipeline0> finalize parent
0:00:07.762260935 3297 0x426800 INFO GST_INIT gst.c:960:gst_deinit: deinitializing GStreamer
0:00:07.767234060 3297 0x426800 INFO GST_INIT gst.c:1097:gst_deinit: deinitialized GStreameri
