Hi Jerry,
I change dtsi and set format to yuyv16, then the camera can’t be opened.
MEDIA_BUS_FMT_YUYV8_2X8 and MEDIA_BUS_FMT_YUYV8_1X16, what the difference between these formats?
And in the extract_pixel_format YUYV8_2X8 and YUYV8_1X16 both stand for V4L2_PIX_FMT_YUYV.
dmesg log :
[ 77.250471] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 78.307280] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 78.307576] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 78.308464] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 78.308678] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=5, csi_port=6
[ 78.308986] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 78.309213] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 5 vc- 0
[ 78.309680] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 80.867891] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 80.868169] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 80.869469] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 80.869677] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=5, csi_port=6
[ 80.869963] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 80.870174] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 5 vc- 0
[ 80.870669] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 83.428449] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 83.428731] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 83.429463] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 83.429675] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=5, csi_port=6
[ 83.429972] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 83.430182] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 5 vc- 0
[ 83.430654] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 83.437243] bwmgr API not supported
[ 120.242967] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
mode0 {
mclk_khz = "24000";
num_lanes = "4";
vc_id = "1";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "yuyv";
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
pix_clk_hz = "74250000";
serdes_pix_clk_hz = "600000000";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "480"; /* 48dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate= "30000000";
exposure_factor = "1000000";
min_exp_time = "30"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
$TOP/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
MEDIA_BUS_FMT_SRGGB12_1X12,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_SRGGB12,
MEDIA_BUS_FMT_SGRBG12_1X12,
V4L2_PIX_FMT_SGRBG12,
MEDIA_BUS_FMT_SGBRG12_1X12,
V4L2_PIX_FMT_SGBRG12
MEDIA_BUS_FMT_SRGGB10_1X10,
V4L2_PIX_FMT_SRGGB10,
MEDIA_BUS_FMT_SGRBG10_1X10,
V4L2_PIX_FMT_SGRBG10,
MEDIA_BUS_FMT_SGBRG10_1X10,
V4L2_PIX_FMT_SGBRG10,
MEDIA_BUS_FMT_SBGGR10_1X10,
V4L2_PIX_FMT_SBGGR10,
MEDIA_BUS_FMT_SBGGR8_1X8,
V4L2_PIX_FMT_SBGGR8,
MEDIA_BUS_FMT_SRGGB8_1X8,
V4L2_PIX_FMT_SRGGB8,
V4L2_PIX_FMT_YUYV,
MEDIA_BUS_FMT_YVYU8_1X16,
V4L2_PIX_FMT_YVYU,
MEDIA_BUS_FMT_UYVY8_1X16,
V4L2_PIX_FMT_UYVY,
MEDIA_BUS_FMT_VYUY8_1X16,
V4L2_PIX_FMT_VYUY,
MEDIA_BUS_FMT_RGB888_1X24,
V4L2_PIX_FMT_RGB24,
MEDIA_BUS_FMT_YUYV8_2X8,
V4L2_PIX_FMT_YUYV,
MEDIA_BUS_FMT_YVYU8_2X8,
V4L2_PIX_FMT_YVYU,
MEDIA_BUS_FMT_UYVY8_2X8,
V4L2_PIX_FMT_UYVY,
MEDIA_BUS_FMT_VYUY8_2X8,
V4L2_PIX_FMT_VYUY,
* The below two formats are not supported by VI4,
* keep them at the last to ensure they get discarded
MEDIA_BUS_FMT_XRGGB10P_3X10,
V4L2_PIX_FMT_XRGGB10P,
MEDIA_BUS_FMT_XBGGR10P_3X10,
$TOP/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
printk("fangzhu pixel_t:%s \n", pixel_t);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_bggr8", size) == 0)
*format = V4L2_PIX_FMT_SBGGR8;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
*format = V4L2_PIX_FMT_SGRBG10;
else if (strncmp(pixel_t, "bayer_gbrg10", size) == 0)
*format = V4L2_PIX_FMT_SGBRG10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "bayer_gbrg12", size) == 0)
*format = V4L2_PIX_FMT_SGBRG12;
else if (strncmp(pixel_t, "bayer_grbg12", size) == 0)
*format = V4L2_PIX_FMT_SGRBG12;
else if (strncmp(pixel_t, "rgb_rgb88824", size) == 0)
*format = V4L2_PIX_FMT_RGB24;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_pwl_gbrg12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_pwl_grbg12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else if (strncmp(pixel_t, "yuv_yuyv16", size) == 0)
*format = V4L2_PIX_FMT_YUYV;
else if (strncmp(pixel_t, "yuv_yvyu16", size) == 0)
*format = V4L2_PIX_FMT_YVYU;
else if (strncmp(pixel_t, "yuv_uyvy16", size) == 0)
*format = V4L2_PIX_FMT_UYVY;
else if (strncmp(pixel_t, "yuv_vyuy16", size) == 0)
*format = V4L2_PIX_FMT_VYUY;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
