Hello everyone! now i am doing a simulation about flow past a 2D circular cylinder by input the python script. The problem i facing is the simulation in the Paraview does not work. where i can set the running time for my simulation? I am just a beginner of python and Paraview. Here is the code of the cylinder.
SPDX-FileCopyrightText: Copyright (c) 2023 - 2024 NVIDIA CORPORATION & AFFILIATES.
SPDX-FileCopyrightText: All rights reserved.
SPDX-License-Identifier: Apache-2.0
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
Apache License, Version 2.0 | Apache Software Foundations
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
import os
import warnings
import numpy as np
from sympy import Symbol, Eq
import modulus.sym
from modulus.sym.hydra import to_absolute_path, instantiate_arch, ModulusConfig
from modulus.sym.utils.io import csv_to_dict
from modulus.sym.solver import Solver
from modulus.sym.domain import Domain
from modulus.sym.geometry import Bounds
from modulus.sym.geometry.primitives_2d import Line, Circle, Channel2D
from modulus.sym.eq.pdes.navier_stokes import NavierStokes
from modulus.sym.eq.pdes.basic import NormalDotVec
from modulus.sym.domain.constraint import (
PointwiseBoundaryConstraint,
PointwiseInteriorConstraint,
from modulus.sym.domain.validator import PointwiseValidator
from modulus.sym.key import Key
from modulus.sym import quantity
from modulus.sym.eq.non_dim import NonDimensionalizer, Scaler
@modulus.sym.main(config_path=“conf”, config_name=“config”)
def run(cfg: ModulusConfig) → None:
# physical quantities
nu = quantity(0.02, “kg/(m*s)”)
rho = quantity(1.0, “kg/m^3”)
inlet_u = quantity(1.0, “m/s”)
inlet_v = quantity(0.0, “m/s”)
noslip_u = quantity(0.0, “m/s”)
noslip_v = quantity(0.0, “m/s”)
outlet_p = quantity(0.0, “pa”)
velocity_scale = inlet_u
density_scale = rho
length_scale = quantity(20, “m”)
nd = NonDimensionalizer(
length_scale=length_scale,
time_scale=length_scale / velocity_scale,
mass_scale=density_scale * (length_scale**3),
# geometry
channel_length = (quantity(-10, "m"), quantity(30, "m"))
channel_width = (quantity(-10, "m"), quantity(10, "m"))
cylinder_center = (quantity(0, "m"), quantity(0, "m"))
cylinder_radius = quantity(0.5, "m")
channel_length_nd = tuple(map(lambda x: nd.ndim(x), channel_length))
channel_width_nd = tuple(map(lambda x: nd.ndim(x), channel_width))
cylinder_center_nd = tuple(map(lambda x: nd.ndim(x), cylinder_center))
cylinder_radius_nd = nd.ndim(cylinder_radius)
channel = Channel2D(
(channel_length_nd[0], channel_width_nd[0]),
(channel_length_nd[1], channel_width_nd[1]),
inlet = Line(
(channel_length_nd[0], channel_width_nd[1]),
normal=1,
outlet = Line(
(channel_length_nd[1], channel_width_nd[0]),
normal=1,
wall_top = Line(
normal=1,
cylinder = Circle(cylinder_center_nd, cylinder_radius_nd)
volume_geo = channel - cylinder
# make list of nodes to unroll graph on
ns = NavierStokes(nu=nd.ndim(nu), rho=nd.ndim(rho), dim=2, time=False)
normal_dot_vel = NormalDotVec(["u", "v"])
flow_net = instantiate_arch(
input_keys=[Key("x"), Key("y")],
output_keys=[Key("u"), Key("v"), Key("p")],
cfg=cfg.arch.fully_connected,
nodes = (
ns.make_nodes()
+ normal_dot_vel.make_nodes()
+ [flow_net.make_node(name="flow_network")]
+ Scaler(
["u", "v", "p"],
["u_scaled", "v_scaled", "p_scaled"],
["m/s", "m/s", "m^2/s^2"],
nd,
).make_node()
# make domain
domain = Domain()
x, y = Symbol("x"), Symbol("y")
# inlet
inlet = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=inlet,
outvar={"u": nd.ndim(inlet_u), "v": nd.ndim(inlet_v)},
batch_size=cfg.batch_size.inlet,
domain.add_constraint(inlet, "inlet")
# outlet
outlet = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=outlet,
outvar={"p": nd.ndim(outlet_p)},
batch_size=cfg.batch_size.outlet,
domain.add_constraint(outlet, "outlet")
# full slip (channel walls)
walls = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=channel,
batch_size=cfg.batch_size.walls,
domain.add_constraint(walls, "walls")
# no slip
no_slip = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=cylinder,
outvar={"u": nd.ndim(noslip_u), "v": nd.ndim(noslip_v)},
batch_size=cfg.batch_size.no_slip,
domain.add_constraint(no_slip, "no_slip")
# interior contraints
interior = PointwiseInteriorConstraint(
nodes=nodes,
geometry=volume_geo,
outvar={"continuity": 0, "momentum_x": 0, "momentum_y": 0},
batch_size=cfg.batch_size.interior,
bounds=Bounds({x: channel_length_nd, y: channel_width_nd}),
domain.add_constraint(interior, "interior")
# Loading validation data from CSV
file_path = "openfoam/cylinder_nu_0.020.csv"
if os.path.exists(to_absolute_path(file_path)):
mapping = {
"Points:0": "x",
"Points:1": "y",
"U:0": "u_scaled",
"U:1": "v_scaled",
"p": "p_scaled",
openfoam_var = csv_to_dict(to_absolute_path(file_path), mapping)
openfoam_invar_numpy = {
key: value / length_scale.magnitude
for key, value in openfoam_var.items()
if key in ["x", "y"]
openfoam_outvar_numpy = {
key: value
if key in ["u_scaled", "v_scaled", "p_scaled"]
openfoam_validator = PointwiseValidator(
nodes=nodes, invar=openfoam_invar_numpy, true_outvar=openfoam_outvar_numpy
domain.add_validator(openfoam_validator)
else:
warnings.warn(
f"Directory {file_path} does not exist. Will skip adding validators. Please download the additional files from NGC https://catalog.ngc.nvidia.com/orgs/nvidia/teams/modulus/resources/modulus_sym_examples_supplemental_materials"
# make solver
slv = Solver(cfg, domain)
# start solver
slv.solve()
if name == “main”:
run()
