data region problem
Hi again,
I’m taking an advice from one of my previous posts and tried playing around with the data region directive. From my understand !$acc data region local(…) would make all arrays inside the list local within the data region. Yet that’s not the case in my program
program main
!=====( Initialization )===========================!
    use accel_lib
    real, dimension(:), allocatable :: randnums, seeds
    double precision, dimension(:), allocatable :: particles
    real, parameter :: PI = 4 * atan(1.0)
    integer :: numparticles, numseeds, seedinit, count(200)
    integer, parameter :: K4B=selected_int_kind(9)
	integer(K4B), parameter :: IA=16807,IM=2147483647,IQ=127773,IR=2836
	real :: am
	integer(K4B) :: gix,giy,gk,ix,iy,k
    write(*,*) "How many particles?"
    read(*,*) numparticles
    write(*,*) "Initial seed?"
    read(*,*) seedinit
    numseeds = int(sqrt(200.0 * numparticles)) + 1
    !future note: set some limit to the number of random numbers since the array might
    !not be able to hold all of it
    allocate(particles(numparticles))
	allocate(seeds(numseeds))
	allocate(randnums(numseeds ** 2))
    call acc_init(acc_device_nvidia)
!=====( Generate Random Numbers )==================!
	!$acc data region local(particles, seeds, randnums), copyout(count)
	!$acc region
		am = nearest(1.0,-1.0)/IM
		iy=ior(ieor(888889999,abs(seedinit)),1)
		ix=ieor(777755555,abs(seedinit))
		!$acc do kernel
    	do j = 1, numseeds
			ix=ieor(ix,ishft(ix,13))
			ix=ieor(ix,ishft(ix,-17))
			ix=ieor(ix,ishft(ix,5))
			k=iy/IQ
			iy=IA*(iy-k*IQ)-IR*k
			if (iy < 0) iy=iy+IM
			seeds(j)=am*ior(iand(IM,ieor(ix,iy)),1)
		end do
		!$acc do vector(256), parallel, independent
        do j = 1, numseeds
			giy=ior(ieor(888889999, int(1000 * seeds(j)) + 1), 1)
			gix=ieor(777755555, int(1000 * seeds(j)) + 1)
			!$acc do seq
			do jj = 1, numseeds
				gix=ieor(gix,ishft(gix,13))
				gix=ieor(gix,ishft(gix,-17))
				gix=ieor(gix,ishft(gix,5))
				gk=giy/IQ
				giy=IA*(giy-gk*IQ)-IR*gk
				if (giy < 0) giy=giy+IM
				randnums((j - 1) * numseeds + jj) = am*ior(iand(IM,ieor(gix,giy)),1)
			end do
        end do
!=====( Main )=================================!
		do j = 1, numparticles
			particles(j) = 1
		end do
	!$acc end region
	do i = 1,20
		print *,randnums(i)
	enddo
	do j = 1,200
		!$acc region do vector(256), parallel, independent
			do jj = 1, numparticles
				if (randnums((j - 1) * numparticles + jj) .lt. 0.1) particles(jj) = 0
			end do
			do jj = 1,numparticles
				if (particles(jj) .eq. 1) count(j) = count(j) + 1
			enddo
			if (count(j) .eq. 0) goto 100
		enddo
100		continue
	!$acc end data region
	open(unit = 2, file = 'data.txt')
    write(2,1000) 0, numparticles
    do i = 1, 200
		write(2,1000) i, count(i)
		if (count(i) .eq. 0) exit
	end do
	write(2,*) "c	Cycle Number	Number of particles"
1000	format (i5,i10)
end program
and all the prints of randnums give me 0.000000. It seems like randnums was made local only within the region directive and not the data region directive.
I also have a few question regarding data transfer
     31, Generating local(randnums(:))
         Generating local(seeds(:))
         Generating local(particles(:))
         Generating copyout(count(:))
     32, Generating compute capability 1.3 binary
     38, Loop carried scalar dependence for 'ix' at line 39
         Loop carried scalar dependence for 'iy' at line 42
         Loop carried scalar dependence for 'iy' at line 43
         Inner sequential loop scheduled on host
     49, Loop is parallelizable
         Accelerator kernel generated
         49, !$acc do parallel, vector(256)
             Using register for 'seeds'
             CC 1.3 : 15 registers; 20 shared, 100 constant, 0 local memory byte
s; 100 occupancy
     54, Loop carried scalar dependence for 'gix' at line 55
         Loop carried scalar dependence for 'giy' at line 58
         Loop carried scalar dependence for 'giy' at line 59
         Complex loop carried dependence of 'randnums' prevents parallelization
     67, Loop is parallelizable
         67, !$acc do parallel, vector(256)
             CC 1.3 : 4 registers; 24 shared, 68 constant, 0 local memory bytes;
 100 occupancy
     77, Generating compute capability 1.3 binary
     78, Loop is parallelizable
         78, !$acc do parallel, vector(256)
             CC 1.3 : 5 registers; 20 shared, 56 constant, 0 local memory bytes;
 100 occupancy
it says that line 38 (do loop after !$acc do kernel in my code) is executed on the host while 49 (the do loop right after) is on the device. If the array ‘seeds’ is local to the device (caused by the data region directive) does the value of ‘seeds’ from the host get carried over to the device?
Hi WmBruce,
The GPU and CPU’s memory are distinct from each other. Any update you make to the GPU copy does not automatically get updated on the host. The “updateout” and/or “updatein” clauses should be used to synchronize the host and GPU memory.
For eaxample, when you print out ‘randnums’, you’re printing the host’s copy of the array, which is zero. Adding a “!$acc updateout(randnums)” before the print loop will update the host values.
Similarly, the following loop is operating on the host ‘particles’ array which needs it’s values updated to match the GPU’s copy:
        !$acc updateout(particles)
         enddo
Some other issues that I see are with the loop with initializes your ‘seeds’. This loop has loop carry dependencies on the ‘ix’ and ‘iy’ variables which prevents it from being parallelized and instead being schedule on the host. This means only your host side copy of ‘seeds’ is being initialized.
38, Loop carried scalar dependence for ‘ix’ at line 39
Loop carried scalar dependence for ‘iy’ at line 42
Loop carried scalar dependence for ‘iy’ at line 43
Second, you linearize the ‘randnums’ array and use a computed index. The compiler can’t tell if all index in a compute index are unique and wont parallelize this loop. Now, you can use the ‘independent’ clause, but it would be preferable to just make randnums a multi-dimensional array.
Finally, ‘count’ is never used on the GPU, so should be removed from the ‘data region’ directive. Otherwise, the GPU’s copy (which is garbage) will overwrite the host’s copy at the end of the data region.
Here’s the full source with my changes. Of course, please double check that everything is correct.
  • Mat
program main
    use accel_lib
    real, dimension(:), allocatable :: seeds
    real, dimension(:,:), allocatable :: randnums
   real :: am
    read(*,*) seedinit
   allocate(randnums(numseeds,numseeds))
   !$acc data region local(particles,seeds,randnums)
       do j = 1, numseeds
         k=iy/IQ
      end do
   !$acc updatein(seeds)
   !$acc region
        do j = 1, numseeds
         do jj = 1, numseeds
            gk=giy/IQ
            randnums(j,jj) = am*ior(iand(IM,ieor(gix,giy)),1)
         end do
        end do
   !acc end region
      !acc do vector(256), parallel, independent
   !acc region
         particles(j) = 1
      end do
   !$acc end region
   do i = 1,numseeds
      do j = 1,numseeds
         print *,randnums(i,j)
      enddo
   enddo
   do j = 1,200
        !$acc region do
            if (randnums(j,jj) .lt. 0.1) particles(jj) = 0
         end do
         enddo
      enddo
100      continue
    do i = 1, 200
   end do
end program
Does updatein/out have the same process as a copyin/out directive of a region clause? In other words, is update faster, slower, or equally fast compared to copy?
Regarding my initialization of seeds, I do realize it is loop carry dependent. I placed a kernel clause in it hoping it would run it sequentially in the device but the compiler says Inner sequential loop scheduled on host. Since I would like to avoid data copies back and forth, how do you force the compiler to run a do loop sequentially on the accelerator? And also why is the compiler forcing all sequential loops into the cpu? Is it because cpu’s do sequential faster?
And last, whats the difference between the vector and parallel clauses for loop directives? and why is 256 a magic number for vector?
Yes, except it gives you control over when the copies occur.
You need to have at least one level of parallelization if order for the compiler to create a kernel. You could add an outer loop with a count of 1 and possibly get the compiler to schedule this on the GPU, but I would advise against it. Each thread processor on the GPU is actually quite slow when compared to the host CPU. The GPU performance is gained through massive parallelization. So any gain you get by not coping the ‘seed’ array, would be taken away by the very slow kernel performance.
Granted, I can’t say this is true for all cases, but the experiments I’ve done all show huge losses of performance when running a single sequential kernel on a GPU.
If you had a parallel outer loop, then the inner loop would be scheduled sequentially on the GPU. It’s only because you don’t have a parallel outer loop is it schedule on the host.
This has been my experience.
The GPU contains N number of multi-processors (MIMD), each containing M number of thread processors (SIMD). The “parallel” clause corresponds to MIMD and “vector” to SIMD. The values of N and M varies from card to card. The utility ‘pgaccelinfo’ will show how many are available on your card.
For full details, I would suggest reading Dr. Michael Wolfe’s articles that can be found at PGI Compilers with OpenACC | PGI and Technical Articles and Publications | PGI. This article is probably the best place to start: Account Login | PGI
It’s not. The vector size will vary per kernel, but will be a multiple of 16.
Hope this helps,
Mat
Thanks for the reply
