Debian 12 doesn't boot after installing driver 560 with kernel 6.10
I have Debian 12 running kernel 6.10.3-1.
I have added the following repo:
deb [signed-by=/usr/share/keyrings/nvidia-drivers.gpg] https://developer.download.nvidia.com/compute/cuda/repos/debian12/x86_64/ /
And then installed the driver with
sudo apt install nvidia-driver nvidia-smi nvidia-settings
The install went well and the kernel module was built, but after rebooting, the OS doesn’t boot and stays stuck on a black screen with a single underscore in the top left.
If I boot with kernel 6.9.12-1 then it works fine.
Can you help me debug and figure out what is wrong with the kernel 6.10.3-1 ?
See https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1078124
Hey @kilian and thanks for your answer.
However, this bug report doesn’t match my situation:
Bug report: NVIDIA 535 drivers fail to build with kernel 6.10
My case:
  • Using NVIDIA 560 drivers
  • Modules build successfully
  • Issue: OS doesn’t boot with kernel 6.10.3-1
The problem persists despite successful module building. Any other ideas?
I just tested with the nomodeset kernel parameter and the system boots…
Any idea why it is necessary and how to configure the drivers properly so that it is not?
[Edit] nomodeset is only required if splash is set.
Are you using Wayland or Xorg session?
Hey @bkdwt !
I run Xorg,
I use SDDM as display manager,
I use KDE as desktop environment.
The splash is using plymouth
Up, I’d like to understand the issue.
You have good ,cause with me do not work i am use linux 6.2 and driver 560
Linux kali 6.8.0-47-generic #47-Ubuntu SMP PREEMPT_DYNAMIC Fri Sep 27 21:40:26 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
nvidia-driver-560
