Hello everyone.
I’ve recently become aware that my laptop is not loading the drivers for Nvidia, therefore using the onboard video.
Running nvidia-smi gives me the following:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Running ubuntu-drivers list giver the following:
dpkg: warning: version 'unsigned-6.10.10-061010' has bad syntax: version number does not start with digit
nvidia-driver-535
nvidia-driver-470
nvidia-driver-450-server
nvidia-driver-555
nvidia-driver-418-server
nvidia-driver-560
nvidia-driver-545
nvidia-driver-470-server
nvidia-driver-550
nvidia-driver-535-server
Ubuntu version: 22.04
Kernel: 6.10.10-061010-generic
Running dpkg -l | grep nvidia, returns the following"
ii libnvidia-cfg1-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-560 560.35.03-0ubuntu0~gpu22.04.4 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-550:amd64 550.127.05-0ubuntu0~gpu22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA libcompute package
ii libnvidia-decode-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.15-0ubuntu0~gpu22.04.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-560:amd64 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA compute utilities
ii nvidia-dkms-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA DKMS package
ii nvidia-driver-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA driver metapackage
ii nvidia-firmware-560-560.35.03 560.35.03-0ubuntu0~gpu22.04.4 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-560 560.35.03-0ubuntu0~gpu22.04.4 amd64 NVIDIA binary Xorg driver
Running nvidia-settings opens the GUI, but there’s a message in the console:
ERROR: NVIDIA driver is not loaded
(nvidia-settings:62941): GLib-GObject-CRITICAL **: 16:40:16.259: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:62941): CRITICAL **: 16:40:16.261: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text.
Please see the README for possible values and descriptions.
** Message: 16:40:16.291: PRIME: No offloading required. Abort
** Message: 16:40:16.291: PRIME: is it supported? no
Running dkms status returns:
nvidia/560.35.03: added
Running sudo modprobe -vv nvidia returns:
modprobe: INFO: ../libkmod/libkmod.c:367 kmod_set_log_fn() custom logging function 0x59826f6e1830 registered
modprobe: FATAL: Module nvidia not found in directory /lib/modules/6.10.10-061010-generic
Running dpkg -l | grep nvidia returns:
I installed the 560 driver from the GUI.
Not sure where to go from here. Any help would be appreciated, thanks!
nvidia-bug-report.log.gz (82.9 KB)
